Question about Casio Cameras
When trying to take a picture it says lens error
It was working, but now it won't take pictures. It says lens error
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Hello Friend,
Send in for Repair.
To submit your camera for repair, please go to https://www.ecasiorepair.com
This is the only Solution from Casio techie hope this info helpful for you..
Posted on May 31, 2009
Nikon N65 won't take a picture
If you have the lens set to the lowest number, you should be seeing a FEE error on the display. The lens needs to be set to the highest number, typically 16 or 22.
Feb 13, 2013 | Nikon N65 35mm SLR Camera
Won't take picture
hiif the key that you use for taking picture does not work in other parts need to change
Jan 03, 2012 | Sony Cyber-Shot DSC-T33 Digital Camera
Won't take picture
try to switch manual focus on the lens or change with other lens then take a picture, if the camera can take pictures that mean the lens is broken.
Oct 05, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
My camera won't take a picture, the lens is protruded and would not go in. I am getting an error message, "Lens obstructed".
may be the lens is disaligned.
Try the following
Firts clean the camera and after
1.- Turn OFF the camera and Softtly push the lens
2.- Pull softly the lens hold pulling turn On the camera.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 19, 2011 | Cameras
Took a picture, then camera was in bag for a moment with lens open. when I tried to take another picture it was blurry, then the lens got stuck , "Lens error", kept making noises, had to take batteries...
What you're experiencing is called a lens error. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 18, 2010 | Nikon COOLPIX L3 Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have the sd1000 power shot canon. i was taking a picture the camera took the picture as normal but when trying taking another shot i got an lens error restart camera.
One thing, you mentioned that the lens error occurred after you wer able to take a good picture. This really sounds like your battery ran down during shooting, and did not have sufficient power to properly shutdown the camera. Focus on your battery as the potential cause first. Note that if the battery is older than a couple years, it may be time for a new one. Rechargeable are not meant to last indefinitely.
Jan 23, 2009 | Canon PowerShot SD1000 Digital Camera
I have error 99 in my camera canon 400d
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Feb 22, 2008 | Canon EOS 30D Body Only Digital Camera
Lens error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Jan 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Cameras Logo
51 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
