Question about Marantz SR-19 Receiver
Audio glitch on Marantz SR-19
Audio clipping in and out on marantz sr19 and making a clicking sound. Is this a heat related problem?
  • noogats May 31, 2009
    cjakHD,
    thanks so much for bringing up speakers.
    a 20 lb maine coon cat recently climbed of the back of the AV rack and pulled some speaker wires.  I had reconnected them incorrectly.
    Now all is well.
    Sniper:
  • 71 Answers
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
Posted on May 31, 2009
I have the same problem. thing is, it's new. i have good cables, the the polks handled the sr19 perfectly for a couple years... then the clipping began. and it's not in a rack.
Todd
Posted on Oct 31, 2011
Marantz sr 5001 turns on but no sound
Answer lies on page 48 of your
Marantz SR 5001 Manual
If problem is not resolved, it may needs servicing.
Aug 23, 2012 | Marantz SR5001
Pcmcia is flashing and no sound out of our receiver
Check page 31 of the manual regarding PCM versus theDTS settings. Choose AUTO surround mode and that might do the trick. Page 29
If the source is external, make sure it is sedning the desired digital audio format - PCM, Dolby Digital, DTS, etc.
Mar 11, 2011 | Marantz SR-19 Receiver
Just picked up a Marantz SR-19, Everything looks like it works but I get No sound out of it. Unfortunately, there is NO remote and was wondering if there is a setting like Mute or a speaker select on the...
A Mute indicator would tell you if it was muted. Make sure no Tape or Multichannel Input are selected by mistake.
There are supposed to be jumpers across the Pre_Outs to Main In's in the back when you're NOT using external amps. You could substitute short RCA cables.
Jan 28, 2011 | Marantz SR-19 Receiver
I want to connect my bravia lcd to my marantz sr770 i can only get two chanel sound from my two front spearker i cant get the surround working
Let's break this into little pieces. Disregarding the TV, does the Marantz otherwise provide multichannel sound?
How is the TV-related audio getting into the Marantz? Analog RCA yields only 2-channel audio.
Two front speakers are only capable of two channel sound.
Jan 24, 2011 | Marantz SR-770
I need to connect to a Marantz SR-19 a record player How do i do it
On the back of the receiver there are connections, usually record player should be hooked up on Phono slot. If Phono is not available, trying using Aux or another slot that isn't being used. After hooking it up, remember the place you hooked it up, turn on the turntable, play a record, then hit the button on the receiver where the turntable is hooked up.
Sep 20, 2010 | Marantz SR-19 Receiver
What would work better for Marantz SR 4200 Apple Composite or component cable? In order to play music through the amp as well as watching videos
Component Video is a big step up the food chain in quality. Component Video inputs are for video only, not for audio. I don't see Component Video inputs on the Marantz SR-4200; only Composite and S-Video. S-video would be a step up from Composite and it carries analog stereo sound.
You don't give any clues as to the source's audio capabilities.
Digital Audio of either flavor is preferable. Grab the best possible TV-related audio from your Cable/Satellite box to the Marantz and run a pair of RCA audio cables to your TV just in case you want to watch the weather channel without hi-fi sound.
Mar 18, 2010 | Marantz SR-4200 Receiver
What is the error POW 5 on a marantz sr 7500
I have a POW 5 failure on a marantz sr 7500. Anybody know how to fix?
Jun 02, 2009 | Marantz SR-7400 Receiver
Marantz sr7200
most likely the audio pre amp & volume control chip
Sep 27, 2008 | Marantz SR-7200 Receiver
Marantz SR-19 Receiver Logo
454 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
