Question about Craftsman 25cc Gas Line Trimmer
Change feed fuel feed line craftsman string trimmer
Just wanted to know i have craftsman string trimmer two lines in gas tank smaller one that feeds carb. rotted bigger one from primer bulb ok is it a chore to replace or find
  • 46 Answers
No should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
Posted on May 31, 2009
Do you have a gas line diagram for gas trimmer
If it has a primer bulb those typically connect to the carburetor at the diaphragm with a return line going to the tank. The larger line is for the carburetor fuel feed from the tank. All lines that are meant to draw fuel from the tank will feature a filter on the end usually inside of the tank.
Jul 06, 2015 | Craftsman 25cc Gas Line Trimmer
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
The Craftsman Sim-Pul string trimmer starts and runs for one sec.
The larger line is the fuel return line from the purge bulb and should have the nylon connector (funnel thing) on it holding it in place inside the tank so the line won't pull out.The smaller diameter fuel tank line goes from the tank to the lower pipe fitting on the carburetor (fuel intake line). This line has a weighted fuel filter inside the tank on it.
New fuel lines are recommended every so often as the ethanol added to our gas nowadays wreaks havoc on the lines and carburetor as well. Get new lines...cut them long....feed them thru holes in fuel tank...grab with tweezers or needle-nose pliars....put on either the fuel filter or the nylon retaining nipple and pull the one with nipple down to bottom of tank...one with fuel filter can stay long to help draw fuel in the tank (yes, it moves around and is supposed to).
Jun 06, 2010 | Craftsman Convertible 25cc. Gas Line...
I replaced gas tank on my trimmer which line goes where one is bigger than the other one
Usually the little brass pipe(s) you are looking at will tell you what you are asking. One pipe should be a smaller diameter than the other. Next time maybe mark the hose or do you have a camera on your phone just take a few pics. Anyhow Good Luck PAL
Apr 28, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Try to replace fuel line craftman weedwacker 32cc/1.9c.u -trimmer-hose all rotten cant figure how to replace
You will need to get some TYGON fuel line. Match it up to the size of each fuel line, some of these trimmer use two different size lines, and remember which size went on which connection. You will want about a foot of each. Cut one end of each line at a 60 degree angle. With a pair of needle nose pliers, feed the angled end of the fuel line into the hole going into the tank and feed it into the tank untill you can see at the tank fill. You cut the angled end off and put your filter on the line. Pull it back until the filter lays at the bottom of the tank. Hook this line up to the supply side of carburetor. Take the other line and put it in the tank about 1" or 2"
then cut it off to fit on the carburetor. HTH
Good Day.
Nov 10, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 28cc gas weedeater gas line connections
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Jun 30, 2009 | Craftsman Garden
Two ports on Walbro carb - which line hooks to which?
Let me know if you need further assistance.
Jim
Jun 20, 2009 | Craftsman 25cc Gas Line Trimmer
Need diagram on fuel lines on a 26 cc craftsman weed eater
Jim
Jun 16, 2009 | Craftsman 25cc Gas Line Trimmer
Lose gas line poulan weed eater
(HINT): when feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
Jim
Jun 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Cracked fuel lines PE550 Edger
Hi Dan,
Yes, more than likely you will have to remove the screws on the back of the trimmer to remove the gas tank.
Jim
Jun 13, 2009 | Poulan Pe550 Gas Edger
Craftsman 25cc Gas Line Trimmer Logo
611 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
