Question about Toro Lawn Mower With Toro Power Tools
Toro lawn tractor
I had to jump start my mower because of a low battery it started and run fine I mowed my yard and then I was mowing my neighbors yard and it just shut off when I turn the key nothing happens not even the indicator gauge will work took the battery to have it checked and it is full charged and good I figure it may be a safty swich that is loose but how do I find them all
  • Anonymous Mar 20, 2014
    Oil level good. Jump started the battery Has gas. Will try to start but will not turn over.
    President:
  • 1,865 Answers
There is a switch on the seat and one on the brake pedal
Posted on May 31, 2009
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
Huskee LT 4200 Lawn Tractor I had to jump my mower today and mowed for 45 minutes, turned it off, added gas, started mowing again for 30 minutes, turned it off and now it won't start, turn over or...
A couple of possibilities, either the main fuse has blown, they are normally an auto motive design and located undrt the the hood of the machine, or the start solinoid has burnt out.
Jun 18, 2013 | Garden
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
Toro 20022 grass buildup
at tractor supply has a paint called slip
May 25, 2012 | Toro Power Lawn Mower
Cub cadet 1515 won't start
I just had the same problem. I installed a new spark plug, sprayed some starting fluid in the engine and it started right up. I mowed my entire yard, and my neighbors yard with no problem?? I'll post more next mow and let you know if it has fixed the problem!!
Apr 29, 2012 | Cub Cadet Street Sign- tractor lawn riding...
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
Cannot have blades engauged when in reverse mower stalls
You are right, the mower has a disconnect for the pto when you try to mow in reverse. You need to turn the key to the mow in reverse position, and now you can mow going backwards.
Hope this helps, Matt
Dec 11, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Toro Lawn Tractor won't start, engine turns
best guess , blocked main jet or water in the carby
an overhaul would be in order
Oct 24, 2017 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
250 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
