Question about Refrigerators
WHERE IS THE DEFROST TIMER LOCATED ?
    Brigadier General:
  • 8,619 Answers
Hi
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 31, 2009
Krazytech
  • 725 Answers
SOURCE: defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
Posted on Aug 25, 2008
SOURCE: maytag fridge defrost timer location
its not a timer , but an adaptive defrost control board, in the upper rigth hand side of refrig compartment, atop the control housing heres the part number 61005988.
check this site ==> http://www.fixya.com/support/t1330051-defrost_timer
Good luck,
Tony Ip
Posted on May 28, 2009
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
  • 93 Answers
SOURCE: Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
Posted on Mar 15, 2009
Where is the location of the freezer defrost timer
The defrost timer is usually located in the top of the refrigerator compartment or in some older models its located in the base of the unit. Normally you will see a small 3/8" hole in front of the timer that is used to move the defrost timer manually with a regular (flat type) screwdriver.
Oct 08, 2014 | Refrigerators
Where is the defrost timer located
The timer is located in the fresh food section. Open the refrigerator door and look up, its in the control housing.
You can purchase the defrost timer at the link below.
GE Defrost Timer Link
Mar 08, 2011 | GE GTS22WCP Top Freezer Refrigerator
Where is defrost timer located
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Jan 14, 2011 | GE GSS25JFM Side by Side Refrigerator
Freezer frosts up and food gets soft
Repair the defrost system, defrost timer,defrost thermostat and defrost heater.
Aug 18, 2009 | Refrigerators
Freezer works fine but refridgerator doesn't
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Refrigerators
Freezer is on and just stopped working
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigerator working not freezer
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 15, 2009 | Refrigerators
Freezer is not cold
Aug 13, 2009 | Refrigerators
Mar 14, 2009 | GE Refrigerators
Defrost timer
Jun 20, 2008 | Refrigerators
Refrigerators Logo
6,828 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
