Reset the ink memory level after replacing cartridge
I refilled my black ink cartridge at office max for my original dell cartridge. I can not get the error message off to reset the ink memory level on a dell 962 printer. Can anyone help me reset? I have replaced both ink cartridges black and colour. the colour cartridge isn't being recognized as full. and the blinking light continues to flash
The ink
level indicator cannot be manually re-set in the newer HP, Lexmark or Dell integrated ink cartridges, thus making
it not usable. The OEMs all leverage 'fusible links' in the nozzle plate (internal to base of ink
cartridge) which physically blows the resistors as the original ink is consumed...thus
resetting the ink cartridge's ink level monitoring capability is simply not
possible. The ink tracking feature is only available with a brand new ink
cartridge.
However, losing this feature is not necessarily
significant, because the ink level indicator usually has 20%-30% ink remaining
when it shows "low on ink".
Therefore, the warning has limited value, because customers who
prematurely replace their cartridges when they see the "low ink"
message are wasting a lot of residual ink.
For information
on North American ink refill services at a major retailer near you (should you
wish to save ~50% on ink costs), general printing problem resolutions or advanced
HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error
bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Most HP cartridges have what's called an ACCUM chip, which doesn't care about the actual ink level, it counts how many milliliters (or droplets) have gone through the head to determine when it's "empty" and therefore refilling doesn't do anything, the accum still says the cartridge is empty.
I managed to successfully refill the black cartridge for the S305; I did it when the printer warned of 'very low black ink' (although it didn't print very well - i.e. grey - until the following day). It kept displaying 'low ink' but printed fine for a few months. I think if you can catch it before the printer decides it needs an 'official' refill or replacement then it works (although when exactly this is is a mystery, as it always displays 'low' for black ink). Yesterday, the printer decided it wouldn't print until the cartridge was changed. Refilled; waited for half a day;replaced several times; turned the printer on and off 5 times with no cartridge in (to see if it would wipe the printer's memory of the cartridge); and spent about 4 hours online trying to find a solution. If it starts working tomorrow, I'll let you know. I don't want to mess about with software that may reset the ink levels. (If anyone finds some that works, please post!) It looks like Lexmark have ensured they can pile in the cash with their original cartridges. I've heard about generic cartridges that are chipped to avoid the above problem - I'll visit my local refill store soon. There must be a way round this! Cheers, Fronter
The ink cartridge is most likely chipped & you would not be able to reset the ink level. Purchase an original or a good compatible cartridge. Refiling newer cartridges is not a good idea.
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low
once it reaches a certain level. The sensor can not be reset. If you
refill an ink cartridge that previously reported low ink, it may print
fine, but the sensor will always report low ink. Buying or replacing
ink cartridges with new Dell cartridges will resolve the low ink
message.
Dell discourages ink refills. Refilling ink may lead to print
quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Dell's proprietary grip on its printers causes this message to appear with any non-Dell or refilled cartridge. The messages/ink filled levels will only be reset if you buy a new Dell ink cartridge or have a way to update their encoding strip.
The good news is that you can still use refilled cartridges just minimize the level warnings to the task bar and ignore them when they come up. Everything should still print fine.
