Question about Vizio VW42LF 42 in. LCD HDTV
Vizio 42 loses sound and is replaced by high pitched buzz /noise.
After I have my Vizio 42" Class Full HD 1080P LCD HDTV on for less then 2 hours the sound cuts off and is replaced by this really loud high pitch buzz/noise. The only goes away once I totally turn off my TV for a minute or so. I have to wait for the Vizio name on the front of the TB to turn Orange before I'm able to turn it back on. This solves the problem for any given amount of time, but it comes back. My first guess it's a heating problem, but I have no way to check other then by feeling the back of the TV. This is getting worse by the day, I can't watch any TV without it screaming at me... HELP! i have the same problem....the sound shuts off ...when i go to a different station..then go back ..it works....so far this will be my ...4th...tv...i even had the vivio repaired ,,,which was all bords on it...ahhhhhhhh still not fixed....had direct tv from the head on the dish to the cable replaced.... WHAT IS NEXT... need help
4 Suggested Answers
SOURCE: Vizio 42" 1080p HDTV LCD.
This is likely due to heat expansion (turned on) and contraction (turned off).
Posted on Nov 26, 2007
Wolfman304
  • 720 Answers
SOURCE: are you able to use
Yes, all new TV's of 1080p specification will have a dedicated PC connection (and should have either a 3.5mm audio socket or 2 x RCA inputs for audio).
The most common way is to use a VGA lead (with 3.5mm audio lead) - VGA out of pc to VGA in of TV. 3.5mm audio output of pc (ie headphone socket) to 3.5mm audio input of TV.
You will just require the correct VGA lead long enough to connect to your pc.
The wireless keyboard and mouse will need to be connected to your pc, and must be within "line of sight" to the wireless receiver.
If you specifically want to use pc output to RGB input (and RCA audio in) of your TV, then you will need to obtain a long VGA to RGB conversion cable, plus 3.5mm audio lead. Have a look on Ebay for a coversion cable.
Cheers,
"Please take a moment to rate this solution with a 'testimonial' and/or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you."
Posted on Jul 31, 2011
SOURCE: loud buzzing noise on vizio tv
Vizio lost picture, made loud buzzing noise now won't come on. Is it repairable?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/karen_e2a7a4a01e0845c1
Posted on Feb 15, 2013
Vizio e371va screen NOT TURNING ON
Sorry to hear that...now a days it,s cheaper to replace then to fix...I had that problem on my first HD TV..a element brand...No hope....trash it went
Aug 13, 2016 | Vizio E371va 37-inch Full Hd 1080p 120 Hz...
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
What size screws do I need to mount the VESA to the back of a 39" Vizio?
Most flat screens use 4, 6, or 8mm, be careful not to use too long a screw.
Aug 08, 2014 | Vizio 39" Class 1080p 60Hz LCD HDTV - Full...
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
Buzzing sound after only 2-1/2 years of service
I suspect you have a bad set of capacitors in the control module. This problem usually starts out as a high pitched noise but can lead to the TV not turning on. Please see the link below, posted by StivO. It gives step by step instructions on how to replace the capacitors. This is a very inexpensive fix.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Apr 13, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Nov 19, 2007 | Vizio L32 32 in. LCD HDTV
Vizio VW42LF 42 in. LCD HDTV Logo
545 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
