Question about Lenovo ThinkPad R61 Notebook
Battery backup problem and processor fan doesnot work properly
I had battery problem . the battery doesnot work without charger and fan also not working porperly.
    Scholar:
  • 89 Answers
You should take your computer into an authorized IBM repair depot. Do you live in Canada? CompuFirm can assist you, we have repair depots all over canada visit www.compufirm.net to view our locations.
I would take it in for repair quick because the fan not working could cause system failure.
Posted on May 31, 2009
Laptop asus K70 only green lights and sound of harddisc and fan
Do you get bios beeps when you remove the memory all together? If no, then I would suspect processor or motherboard failure.
Feb 13, 2015 | ASUS Computers & Internet
NEW HP Spectre 13T-3000, 13.3" Touch will not run with the battery and shuts down randomly
you can use the unit without the battery. Remove the battery, plug in the charger/power supply and turn on the unit and wait for the result. if the problem persist?..... maybe the fault is in CPU fan. check the fan...overheating the processor. Cleaning the heat sync and reapplying silicon compound on CPU's can cure the problem.
Sep 02, 2014 | Computers & Internet
Computer wont start, despite all components working, cpu looks corroded
Pat,
Usually you diagnose these by process of elimination. Get down to the bare bone mobo without anything but the processor, good RAM (switch out if you can with different ones), and Power Supply. Eliminate everything else, no cd, no floppy, no hdd, no video cards, no sound cards, no cards at all really.
More than likely it's a bad power supply. Take the power supply to your local computer shop and they should test it for you for free... don't let them charge you for it. If it's good then test the cpu.
Hope this helps :)
Sep 22, 2013 | Compaq Computers & Internet
Powerware 9120 6000i model indicates a charger failure. It is the first time that we opened this unit and we do not know the location of the charger circuit (we do not have a schematic diag). Could you...
The charger in powerware 9 series 9120 6000i ,the fan is of a quality that it fails and the heat sink does not get sufficient cooling ,it runs on 12 volt ,i replaced it with a cpu fan from a mainboard on a pc and it works perfectly now. make sure that the fan is running else the charger might go in protection or can fail due to the transistor on heat sink fails.
Feb 08, 2011 | Powerware 9120 UPS System
I am using acer aspire 5310 laptop ,i have the battery too but its not poering on in battery what to do please help me
does the laptop works without the battery to see take the battery out and then plug it with the charger and the turn it on if it is turning on then fine now put the battery back and check it without the charger if it doesnot then the battery has gone bad
Oct 27, 2010 | Computers & Internet
When I turn on the power the Compaq Screen flashs and then I get Press to resume to setup But nothing happens when I do either. I tried to use the recovery disk. You can hear the fan, you can hear the CD...
This is likely to be as a result of your processor over-heating, maybe because of your environment, or because the fan is not cooling the processor properly again.
Therefore my suggestion would be for you to unscrew your laptop (If you can do it by yourself), and try to clean, or better still replace your processor fan.
If you cant do it by yourself, you can easily get a technician to do it for you.
Also, remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
I have actually had the same case before, and after doing what I've just told you, it stopped behaving like that.
Then always make sure that your laptop is in a well ventilated, cool environment and that the environment is free from dusts.
Kindly let me known how it goes after you've tried this.
Hope this helps you out.
Nov 29, 2009 | HP Compaq Presario V2000 Notebook
How do i access the processor fan for hp pavilion dv5000 because it gets extremely hot in the top right corner, then shuts down. and the fan only runs for like 2 minutes every 30 minutes
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
AND
With the ear bud clean the vents of the fan and check whether it is happening again. And if it is happening again do the bios update of the computer from the hp.com website and check.
Oct 28, 2009 | HP Computers & Internet
M600 does not power up after being left in drawer for a month
In your case battery might have gone deep discharge first charge your battery properly to full charge then switch on the phone. If you battery doesnot hold the charge then replace the battery.
Jul 22, 2009 | Orange SPV M600 Smartphone
APC Backup UPS Model # BK200C salvageable?
Yes, but the battery may not be any good, though, and trying to charge it may damage the charger. A new battery is about $20. The surge suppressor will still work without the battery as long as it is connected to a properly grounded 3-wire circuit. If you decide to take a chance and charge the old battery, take precautions like keeping a watch on it should it explode or catch fire. Not trying to scare you, just looking at worst case scenario.
Jan 27, 2009 | APC Back-UPS 200 UPS System
Lenovo ThinkPad R61 Notebook Logo
152 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
