Question about Dell Inspiron 1525 Notebook
Start up services.
I bought the laptop used but they did not clear all the old stuff out. so when I seen in the start up there are a'lot of things running. I turned off all the ones that said keep and kept the ones that said enable. and it did speed my computer up a'lot, but it then had problems in other areas. which one can I turn off I am running windows Vista.
    New Friend:
    Problem Solver:
  • 14 Answers
Vista is no longer supported. Install a Linux distribution
Posted on Oct 20, 2017
SOURCE:
safenude
  • 124 Answers
SOURCE: file sharing between computers
Thanks for giving me the opportunity to help. Try the following:
On your laptop with Vista, click start, then network from the right side. This will take you to the Network Screen. Click on the Network and sharing screen. Click on options such as file sharing, printer sharing etc. Make sure that you can see each device your your network. If you can't you must go to each PC and use the network options on the XP machines. It's pretty simple, just follow the instructions that the wizard provides.
I hope this gets you up and running. Thanks for using Fixya.com
Posted on Jan 27, 2009
joecoolvette
  • 5660 Answers
SOURCE: dell inspiron 6400 won't power up
Believe that this is an indication about the CMOS battery. It shouldn't have gone bad though, as the average lifespan of a CMOS battery is 9 years.
Dell's terminology for this battery is, "Coin-Cell Battery". No matter what name it is being called, it is a round battery like the type used in a watch. It is a CR2032. It is about the size of a U.S. nickle. This battery is readily available in many places. (I have even found them at the pharmacy!)
How to change it?
This is Dell Support, and the Service Manual for the Inspiron 6400, plus more specifically the page on how to change the Coin-Cell Battery. There are photos, and information.
http://support.dell.com/support/edocs/systems/ins6400/en/sm/coinbatt.htm#wp1127281
(Just copy and paste the above link into your address bar, then press the Enter key. Not trying to insult your intelligence)
1.Remove the AC adapter, (Charger), if plugged in.
2.Remove the battery from the battery bay.
3.Work on a table. It is recommended to buy, and use an ESD wrist strap. (Electro Static Discharge) This prevents static from your body, from frying out the delicate computer hardware components, inside your laptop.
(Example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245&cp=&sr=1&kw=anti-static+wrist+strap&origkw=anti-static+wrist+strap&parentPage=search)
The ESD wrist strap has a strap that goes around your wrist, and in the strap there is an exposed piece of metal. This metal touches your wrist. The other end of the wrist strap has an alligator clip. This clip is attached to a good ground source.
The 'Good Ground Source' for many techs, is one where the alligator clip is attached to a ground in a house, or shop's, 120 volt electricity supply. In otherwords, that round hole on the bottom of a receptacle. (Wall socket. Two flat blade slots on top, and a round hole in the middle, on the bottom)
For me this = NO! You're not going to catch this kid, plugging my wrist to anything that has to do with high voltage electricity! Yes, it would be safe, but I have this thing that if lightning strikes a transformer on the utility pole outside, and follows the power wires to the house, or shop, then to the Service Panel, and finally to the LEAST possible source of resistance, Ummm,.....that would be ME!
Do you have a desktop computer? Unplug it from the surge protector. Open the computer case, clip the alligator clip to the metal frame.
(Or use an empty computer case like I do)
In 20+ years of repairing computers, I have never had a problem with this method.
(Sorry about the 'windy' explanation!)
The Coin-Cell Battery is under your keypad. However to remove the keypad, you must remove the Hinge Covers.
You have to remove the Hinge Covers, that are for the hinges of your LCD screen.
It's real simple.
Now remove the keypad, then the Coin-Cell Battery. The Dell Support link shows you, and give clear instructions.
Posted on Aug 01, 2009
  • 52 Answers
SOURCE: Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Posted on Sep 25, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: dell inspiron 1545 laptop not working
Sounds like the hard disk could have went bad. try running a diagnostic from your discs and if you receive an error, report it here or to Dell. If you did crash the hd, you will need a new one. I hope your machine is under warranty.
Posted on Nov 05, 2009
  • 112 Answers
SOURCE: I can't find my local area connection...how can i can i get it?
may in service pack 2 there is no LAN but you have to reinstall to he your original service pack that you to contact dell and one more thing for you have to install drivers of connection or internet because your service pack2 has not installed drivers
Posted on Dec 16, 2009
Please i need schematics for start push button of hp -cq 62 laptop
buy a used one on ebay
HP does not sell them this old
nor do they sell schematics, or did you really mean the assembly drawings seen in all HP service manuals. clear as day.
its an old compaq.;cq62-407AX
8 years old?
your 407 is missing here.
http://partsurfer.hp.com/WSearch.aspx?Wchar=Y&searchText=cq62-4
so zero support from HP.
Feb 20, 2018 | HP Computers & Internet
97 f150 automatic 4.2L v6 when I'm driving the overdrive light on shifter starts flashing and the transmission starts shifting between gears a lot and it shifts very hard like the transmission is bad.
Hi,its posible that the gearbox needs a new filter and new fluid,when thhese two things get old the gearbox wont shift propperly,also for a fuew quid you can buy some xado wich will also give smoother gear change and longer life,all the best.
(I would just like to make it clear I dont have anything to do with the componey I just know the stuff works)I use it all the time and swear by it.
May 01, 2015 | Cars & Trucks
Why can't my new 8.1 laptop get on my old gnet modem
Probably, from what I've seen 8.1 isn't compatible with lots of stuff.
Jun 24, 2014 | GVC Gnet Modem
I've seen commercials on teevee for this product
I thought I would help you out and give you a old mechanic tip that might help you. What you do, is get some transmission fluid and put some on a soft cloth, and apply to the covers, and gently wipe and rub slightly, keep it somewhat wet. Let dry for a bit, the with clean cloth wipe off hard, and really scrub and this should help a lot. Old detail trick, for used car lots. There is another product you can buy as well that is cheaper than the stuff on tv. You can get it at a camper, canopy shop, they use it on plastic canopy windows ( you know those canopies on back of pick up trucks) it is in a little bottle and it is a cream compound that you apply like wax. I hope this helps, Mike from Fixya
Sep 15, 2011 | 2004 Honda Civic
I bought my acer laptop on 12/20/09 so its not even a year old and its starting to have black circles all over the screen i dont know what it is or why its happening to my computer? thanks jen
Seening that the laptop is under a year old the best thing to do is bring it back to the shop and get them to sent it back to acer, before you let them send it away backup everything you need from the laptop. and one more think acer are very slow at sending back repairs, i know this because i send computers back to them all the time for my work
Jun 16, 2010 | Computers & Internet
Free space of Intel Centrino Duo is lessening
Any anti airus program will use more and more disk space as time goes on. Every time it updates, it gets more virus information. Also, if you use the internet, you will get cookies and junk from every site you go to. Under tools-internet options, clear everything off when you get done with the internet. Anything you add to your computer and then remove, leaves a lot of info. in the registry files. Ge a registry cleaner and run it. It will not only get rid of a lot of junk, it will also help your computer run faster. There is NO way to keep your hard drive from geting less and less space as time rolls on, other than removing a lot of stuff.
Get AVAST AntiVirus. It's free and just as good as the ones you pay a lot of money for. It also updates automatically.
Dec 26, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
DVD not showing a clear picture
test test test 17:05
danke bitte
do not answer test test
sorry
Jul 04, 2009 | Televison & Video
Comms failure message
Good to excellent chance that by not using the ink jet for "years" that they are hopelessly clogged. You can try the cleaning procedure but I'd bet that your lack of use has ruined the ink jet portion.
I had this happen to me and went through (and wasted) a lot of time and money cleaning the printer and trying to get ink to come through.
On the bright side You have a lovely scanner. Time to go buy a printer. Sorry but I think your "printing in years" is probably a self imposed problem created by lack of use. Ink's pesky and clogs if it's not spit through at regular interfals.
Jan 05, 2009 | Canon BJC-85 InkJet Printer
Change from analog to digital
There are digital scanners available, but their use may be limited, depending on what you want to listen to.
A lot of scanning enthusiasts have spent a lot of money, only to discover their new digital scanner is useless.
Many emergency services are on digital BUT, they are also encrypted, so even with a digital scanner, encrypted transmissions cannot be heard.
Before parting with your cash... do some research on what digital signals can be heard in your area, keeping in mind that although some digital services are currently transmitted 'in the clear' there may be plans to encrypt them later.
Hope this helps.
Dec 31, 2007 | Uniden BC248CLT Base Scanner
Dell Inspiron 1525 Notebook Logo
26 people viewed this question
Clive
Clive
Alun Cox
