Question about RCA 27V520T 27" TV
Help my rca model 27v412t tv is going nutts
It turns off and on by it self I cant find any burn marks on the bords and I need my tv back.
RCA HAS A KIT! which includes different solder and some paste for a better solder flow!
I resoldered mine without knowing that and it lasted 7 months before it started up again.
so now I'm on the way to givin it a total resolder on every component that creates heat , hopefully that will last another 7 months at least , also note that I replaced R033, R034, and C230 , if this continues to do it again I'm going to replace EEPROM and x001( crystal at 8.000mhz) and the IR sensor. I'm guessing that rca must have known that the sets heat up and the solder joints become bad ,I belive that the flyback and other hot components will do the same thing , as I also belive most of the models of this type chassi will encounter the same issues comming from bad solder or dried solder, if problem is not corrected soon then EEPROM the crystal and other components will suffer severe dammage, then the set is just another piece of history.
good luck to those who own one
Posted on Oct 22, 2008
MODO DE SERVICIO PARA UNA RCA MOD 27V412T Y EL CHASIS M134C
Posted on Sep 09, 2008
Same here same model-
Been in the shop since Oct 07 and part (keyboard) has not come in as of today 1-09-08 NO Parts being made.
RCA sucks they just want you to have to buy a whole new TV!
Posted on Jan 09, 2008
My RCA 27V412T TV turns the screen red
Can you see a picture at all or is it completely bright red? Is there sound?
Dec 29, 2012 | RCA 27V520T 27" TV
Im looking for the manual for my RCA 27V412T
You can view or save your manual from this site to view in PDF or print if so desried.
http://tv.manualsonline.com/manuals/mfg/rca/27v412t.html?idRes=11396722
Apr 02, 2012 | RCA Televison & Video
How to take of the FPA on a RCA 27V412T
Hello
To unlock the FPA lock of RCA tv, do the following. One amoung the process will surely unlock your RCA. You must have its original remote control handset to do this..
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
May 22, 2011 | Televison & Video
Why does my RCA model# 27V412T turn on and off by itself? It's does not stay on long enough for me to reprogram the remote.
Hi There,
Sounds like your Startup Relay is intermittent. Contacts are closing (tv on) then dropping out (tv off). Worn or burned contacts do not make a good connection when they close and start to burn and overheat causing the contacts to open. When they cool down they may make contact again for a very short period. You need to replace the Start up relay. I hope this helps and thank you for using FixYa!
Mar 29, 2009 | RCA Televison & Video
RCA 27V412T
check your tv's power cable inside the tv. make sure its not frayed. also take the batteries out the remote, it could be turning off the tv.
Dec 29, 2008 | Televison & Video
27V412T turns self off
You have a bad vertical deflection IC and/or bad capacitors in the vertical circuit. The parts are inexpensive and can easily be replace by a service technitian.
Mar 14, 2008 | RCA 27V520T 27" TV
Rca tv model # 27v412t
What are your sympoms? keever
Mar 02, 2008 | RCA 27V520T 27" TV
Turns off/ on by itself model 27v412t
well my tv was doing the same thing my prob was the buton bord.the ezyest way to check it was to take the back off and find the wires that come from the boton bord the plug the tv in and turn the tv on wile its on unplug the boton bord wires if the tv stays on that is probly your prob the bord dont cost much I found a site on here that has them for under $5.remember to be carefull when checking it out tv car be very dangerus.I found that if I beat on my buton bord alittel it would work for awile hope this helps
Oct 26, 2007 | RCA 27V520T 27" TV
TV turning on and off
Try reset.Unplug AC cord for a few minutes, longer,if doesn't work.plug back in--try again.
Oct 09, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
504 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
