Question about Hayward Pool Products Economy 1 Hp Above Ground Pool Pump
Hayward above ground pool pump will not start.
When the electric switch is flipped, the pump hums but won't come on. The shaft is not turning. I can move it freely either way by hand so its not froze, but it will not turn
Is there a fuse inside the hayward above ground pool?
Posted on Jul 19, 2011
  • 46 Answers
Sounds like the windings in the motor are shot! but does it have a capacitor? if it does you could simply have a bad starting capacitor so don't let it hum for that will surely scar the windings
Posted on May 31, 2009
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Hayward Pump motor, hums but won't start. If I turn the shaft it will keep running but once I turn if off it will not run until I do the same thing again. I have replaced the capacitor but still the s
1 or 2 capacitors on this motor?
Sometimes there are two...
One is a "Start" capacitor and if a 2nd one, that one is a "Run" capacitor.
If only 1 capacitor and you have replaced it... if not a faulty capacitor, then your windings are shot?
When I test a motor with this symptom, I will use the "Clock Face" method of checking for "Dead Spots" on the winding/stator:
Once you have removed the shaft cap on the back of the motor, I presume you have done this since that is only way to turn the shaft manually to get it to run in the manner you described. Place a small mark (1/4" long?) on the outside perimeter of the shaft, say at the 12:00 position. See picture attached...
Then flip switch, does it start or hum?
Then rotate shaft until your mark is now at the 1:00 position. Flip power switch, running or humming?
Do this at all clock positions as you turn/rotate shaft until you reach 12:00 once more. If the pump hums at all clock positions completely dead motor or bad capacitor. If a dead spot is at only one clock position, then absolutely, bad motor - either rebuild or replace.
Coincidentally the motor may stop each time on a dead spot, where the motor won't start due to a fried portion of the stator/winding/armature, only a major repair fixes this. The purpose of the test is to place the position of the stator in a different position in relation to the windings. If humming all the way around, then possibly a bad capacitor, because it is not starting in any position. If it starts say at all positions except 4:00 and 9:00 then motor is bad.
Good luck
Aug 30, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
Switch is turned on but pump would not run. shaft turns by hand
It's junk made by Hayward. I've gone through two motors and am starting to hear the familiar noise of another motor about to fail.
Jul 05, 2012 | Hayward Pool Products Economy 1 Hp Above...
Above ground pool pump humming
BLOW OUT THE BACK OF THE MOTOR WITH COMPRESSED AIR. THERE IS TRASH IN THE START SWITCH , AND IF YOUR LUCKY IT WILL FIRE BACK UP. IF YOUR IN THE LONGWOOD FL AREA I DO THIS FOR FREE FOR MY ABOVE GROUND POOL CUSTOMERS
OTHER SHOPS MAY DO IT ALSO, JUST CALL AND ASK
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL 32750. PLESE VOTE YES OR NO IF I WAS OF HELP
May 19, 2012 | Hayward Pool & Spa
Hayward pump hums only
Replace your start capacitor ... before you do that ... is the hummng the motor withoug the impeller? Your impeller may be broken.
Jun 25, 2010 | Hayward Pool Products Hayward Power Flo LX...
Hayward flo pump motor repair
What exactly is wrong with your pool pump? If it won't start at all, check for improper or loose connections, blown fuses or tripped breakers, and open your switches and replays. Manually check the rotation of your motor shaft. Make sure that there is free movement and no obstructions. If the motor hums, but won't start, check for obstructions and check the Centrifugal switch to see if it is stuck in the open position. If you have low flow, check pool pumps for clogged or restricted strainer/suction line and discharge line of filter. You could also have an air leak in suction (bubbles issuing from return fittings). Low voltage could cause loss of suction. Check for plugged or restricted impeller.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
I have a hayward pool pump. I ran the back wash
It sounds like the start switch contacts are not making good contact or there also may be a weak capacitor. These possible solutions do require a basic knowledge of motors to remedy. Start contacts can be cleaned and adjusted until proper replacement can be done.
Aug 16, 2009 | Hayward Pool Products Economy 1 Hp Above...
I have a proline 2hp above ground pump. A snake
The impeller is still jammed you need to get it cleaned out. You can try with a pair of needle knose pliers if that doesnt work your gona have to remove the pump bolts that hold the motore to the pump pod. Remove the bolts around the motor and seperate it this will give you better axcess to the impeller. Clean it out and try to move it if the impeller will not spin freely with the debris removed the motor has burned up .
Jun 24, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Hayward Pool Products Economy 1 Hp Above Ground Pool Pump Logo
932 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
