Question about Dishwashers
DISHWASHER MY DISHWASHER WILL NOT WORK BECAUSE THE QUICK RINSE LIGHT IS ON (BLINKS OFF & ON). START OR ANY OTHER BUTTON DOES NOT WORK. I FLIPPED THE BREAKER SEVERAL TIMES AND ALWAYS GET THE SAME THING.
  • MAMALISA Oct 24, 2007
    model no. 665 16919001 kenmore elite
  • MAMALISA Oct 25, 2007
    i did as you instructed. the stuck button went off and a code 4H displayed. then it went back as it was stuck on the quick dry button. what does code 4H mean?
  • 290 Answers
It sounds like a faulty console panel. I will need the model number to diagnose it any better. Open the door and the model and serial number tag should be on the side of the cabinet, usually on the left. Respond back with it and we will see if we can walk through the problem.
Thanks/Mike
Posted on Oct 23, 2007
  • Michael  Lindley
    Michael Lindley Oct 24, 2007
    Thanks for the model number.
    First, lets make sure the console is not locked.
    Hold the air dry button in for 4 seconds and see if the lock light comes on. If so, hold it down for 4 seconds again and it should go out. If it doesn't light up, try to cancel the cycle.
    If this has no effect then you have a stuck switch in the console.  When the machine is working properly, if you hold any of the cycle buttons down for more than 3 seconds it will start flashing until you release it. What is happening with your machine is the quick rinse switch is stuck. The only other quick fix you might try is to press and release the quick rinse button a few times to see if you can free it. I doubt this will help but it's worth a try.
    This means the whole plastic console will have to be replaced. You can order it from Sears.com for $129.49 plus shipping for the white console. Price may vary by color.
    I have run into this problem several times and almost always there has been a child or grandchild that has been playing with the diswasher buttons to see the lights change. (I have a 2 yr old that I have to keep an eye on around the dishwasher)
    If you want to try to repair this yourself, post back and I will walk you through the steps. If you choose to have Sears repair it they may offer you a Service Smart Agreement that will cover the repair plus extended coverage. If the price is less than $250, I would advise you to take it. It will cost much more than that to have them come out and repair it.
    Let me know what you decide.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Oct 26, 2007
    4H is the display for a 4 hour time delay wash. I am afraid you will have to replace the console. There is a slight chance the problem is in the electronic board but my experience with these machines is the console is your problem.
    Thanks/Mike
SOURCE:
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Dishwasher cancel/drain light is blinking and when I hold it in the light wish blinks. Flipped the cicuit breaker but lights still flash. Cannot find a reset button or something
Google:
kenmore dishwasher light flash
for the solution on which combination of buttons to press to reset it. Worked for me tonight.
Apr 15, 2011 | Kenmore Dishwashers
Pots and pans light, quick rinse and cancel buttons all blinking. unit will not start.
Try to pull the fuse or turn off the breaker for 30 seconds. This should reset the electronics and possibly fix the problem.
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashes on my KitchenAid KUDS01DJ and it wont run
My dishwasher did the same thing. The repair guy fixed it and told us how to reset next time it happens: press: Hi temp then Energy saver then Hi Temp then Energy saver do this quickly over 5 seconds all the lights should come on Then,turn off the breaker for one minute then, go back to the dishwasher and press cancel. All the lights should turn off. Start dishwasher as usual. If the cause was just a brain fart, the dishwasher should work.
Jun 03, 2010 | KitchenAid KUDS01DJ - Multiple Color...
I cannot change cycles and the dishwasher won't turn on.
Micro controller problem. Take help from authorized service center help.
Apr 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kenmore elite dishwasher has no lights or any sign of power. Breaker not flipped, power good....
press back and forth the sani rinse button and high temp button..keep pressing back and forth repeatidly until lights will light up and it resets the system...
Feb 27, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Fisher paykel dish draw
Turn the power off to your dishwasher for about 30 seconds by flipping off the circuit breaker in your home's breaker box. When you turn the breaker back on it will have reset the dishwasher and should begin working just fine.
Aug 24, 2008 | Dishwashers
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Dishwashers Logo
398 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
