Question about Panasonic DVD-LS83 Portable DVD Player
The discs will not load on the dvd player
The discs that i insert into my portable dvd player from panasonic will not load and the player says to insert a different disc and it will not work and i have tried all the discs in the house and my mom's video stores and none of them will work
  • 822 Answers
Check & clean the lens.
Posted on May 31, 2009
Won't complete the load disc process
Loading may mean it is not seeing the disc---A dirty or bad optical pickup is possible if you get this error with every disc.
Jun 06, 2012 | Audiovox D1812PKG 8 in. Portable DVD...
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Dvd player says no disc when there is a disc in
Hi
Please check weather you have inserted the disc ,whose format is supported by your KOSS player.
If the formatt is not been supported /regonised by the player,It shows as NO DISC only.
check with some other disc which you previously played.If it plays the disc which you using has the problem.
Thanx
Jul 26, 2010 | Dynex DX-PDVD7 Portable DVD Player
Disc does not appear to load. When inserted in
If you have a disk that you know works, try it. Make sure the disk is not upside down.
Dec 29, 2009 | Polaroid PDV-0823A Portable DVD Player
When the disc is loading it stops and says
pls. check regnel code seting .
use remote cantrol on setup menu open and selact regnal code set Adealt . or all regnel code after then use disc is play caractly
if not then problum is inside your disc player .
Use. lance clenar disc and clenig your disc player lance.
Oct 20, 2009 | Venturer 3.6" Portable DVD Player
Philips PET710 DVD player shows 'no disc' when disc inserted
I have the same problem with my portable dvd player and found that cleaning the lens of the player using a non-alcolhol wet nap for cleaning eye glasses worked well. I also found the rail that the optics runs along while playing needed a very small amount of silicone greese applied using a Q-tip. You may find that the optic unit may be "stuck" somewhat but can be resolved by gently moving the optic along its guide using a finger.
This changed my unit from not working at all, to working intermittantly sometimes having to vary the player on and off to recongnise the disc. Hope this works
Jul 28, 2009 | Philips PET710 Portable DVD Player
Portable dvd player won't load disc
well..I ve heard this problem many times..a DVD player says "no disc" or "invalid disc" only if the disc that you have inserted is damaged or else the DVD reading lens has been damaged when you dropped your player..! That maybe the problem..I suggest it is better to show it in some shop ! or to the authorized dealer itself for better results..ok
May 25, 2009 | Televison & Video
Panasonic Portable DVD Player LS50
Can you see or hear that the disk is spinning up normally as it did before? I understand that the small, spin-motors on these portables often go bad.
Jun 06, 2007 | Panasonic DVD-LS50 Portable DVD Player
Panasonic DVD-LS83 Portable DVD Player Logo
274 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
