Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
My tv is turning everything purple like it is magnatized or something.
When the tv is on the bottom right corner is purple. It still displays normally but in purple tint.  Especially noticable when the screen is white.
  • Randyi Nov 08, 2007
    Mine is just starting to turn purple at the bottom. It's the 50 in model KDF-E50A10. Same thing. Hope someone finds a solution.
    Any assistance would be appreciated.
    Randy
  • kwpeace Nov 15, 2007
    Call sony support. Seems that they are covering the replacement of the optical block until the end of the year. Pretty spending part I guess around $1250 so don't mess around to long with it.
    In English: 1-800-222-7669 or 1-888-772-7669
    Hours: Mon-Fri 9:00AM-10:00PM / Sat-Sun 10:30AM-7:15PM EST
Call sony at this number and tell them what your tv is doing? If it is like mine they will replace the optical block. It seems that Sony will cover parts and labor if you do it before the end of the year. If the numbers don't work just go to sony's website and check for warranty or support information
Posted on Nov 15, 2007
Today my haier Plasma TV (42HP25BAT) did a terrible click sound and post which the screen of TV went purple with out blue color and less brightness than normal. When there is no signal to TV , it...
Purple? Would that be magenta? That's what you get when you lose the green color. Lower brightness may be due a shift in one of the power supply voltages. I'm not familiar with the layout of this model, but the first thing I'd do is inspect the power supply to see if something exploded - possibly an electrolytic capacitor.
Another possibility is a high-voltage component on the plasma driver board. Check anything mounted on a heat sink (metal plate or slab with fins).
Are the black spots just in one corner of the display? Do they show up the same no matter what the program material is? If so, I'd be concerned that you had an arc inside the display itself and it is damaged. The arc could have taken out the green drive. It is possible that it's a problem in the video circuit, but usually that would show up as a bad row or column. (If it is indeed a fault due to arcing in the display, you may able to see a difference between the bad areas and the rest of the screen with a magnifying glass and bright light when the set is turned off.)
Jun 11, 2011 | Televison & Video
Color in corner going bad
U drop this tv before,like CRT yoke in cathode ray tube have big jumbo.Any magnatic around also,Tries moves the the difference directions might help,like northwest,southeast,so on.
Oct 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
42 plastma problem
Bad Capacitors in Power supply. IF doesnt help changing Capacitors Replace Power Supply Board
Feb 28, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Color on screen is not uniform
get a degaussing coil. crt magnatized..or worst shadow mask broken loose inside crt.  to ck turn on hit crt with open palm. if colors move bad bad.
Nov 12, 2008 | Sanyo DS27800 27" TV
Colors are messed up
the deguasser in your tv may not be working right..or the magnets in the corner of your tv has moved....it can be manually deguassed but a tv shop would have to do it..
Jun 28, 2008 | Sylvania 6427TE 27" TV
Sony trinitron 32 " purple area on screen
Check any magnatic device near TV which causes purple color on screen. That device can be Speaker, Electronic toy, Watch like that carring piece of magnet inside. Remove that device and turn OFF your TV for half a hour, then power again. Hope the color will be fine n normal on entire screen.
May 31, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
I have a pioneer dv656a dvd player and on some dvd's i play on my samsung ps42q96hd plasma tv, it displays horizontal lines that move from bottom to the top of the screen constantly. Is this normal for a...
Try disconnecting everything from the tv *except* the DVD player (that includes cable tv). You are using a component or digital connection, right? Some of these HDTVs are **** at displaying a composite feed. If this clears up the problem then the lines were probably caused by a fault in your cable tv, and you need to take it up with them.
ANYWAY, if the rolling lines remain even with everything else unplugged, it could also be electrical interference from something near by, like power cords or something.
Mar 24, 2008 | Televison & Video
Philips Magnavox 27MT5405 TV problem with color
hi sir that thing hapen when the magnetic field around the screen is varies evry time the tv set is switched off then on after an hour may be , it comes to its normal magnetic field state and when not so there are two reasons 1- check for around the tv for any magnetic items ,speakers , cassette recorder or any magnetic motors clear the around electric items if not working after an hour of reset then refer to 2 2- there is an electronic element inside calles PTC it should be deffect it is a small three legs element and is giving the first power to the colis around the screen to make proper magnetic field check it by qualified person please please don't forget to rate the solution and remember i am here at your service regards ]
Apr 30, 2007 | Philips Magnavox 27MT5405 TV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
671 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
