Question about HP PSC 1315 All-In-One InkJet Printer
Won't pint no printing connections
    Sergeant:
  • 145 Answers
Have you install the driver correctly??
or have you check the printer logo on the control panel - printer and faxes? is it exist? I mean your printer series
Posted on May 31, 2009
Error 651?won,t print from note pad
Follow these steps:
Go to control panel following location
Click on Network and Internet\Network Connections
Right click on broadband connections [WAN Miniport(PPPOE)] and un-check set as default
Jan 12, 2016 | Lexmark X2250 All-In-One InkJet Printer
Kenmore 407 50 pint dehumidifier won't drain through hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Oct 13, 2012 | Kenmore 90701 70 Pint Dehumidifier With...
Soleusair 45 pint dehumidifier won't drain through hose
We have a Soleus Air 30 pint that initially would not drain through the hose that we attached and dropped down the sump drain. After reading here, I tried tilting it back about a quarter inch and that didn't fix the problem. Then I tilted it forward a quarter inch (I put a couple pieces of cardboard under the back wheels) and it started draining properly. It is doing a marvelous job of dehumidifying the house now!
Mar 04, 2012 | Dehumidifiers
I have lost my instruction manual and cannot change te temperature and humidity settings. How do you do this?
Here is a link to an Owner's Manual for a Haier 45 pint dehumidifier. Not sure if yours exactly like it or not, as you didn't mention a model number. You can download and print the manual for future reference.
http://www.haieramerica.com/cool-heat-air-quality/dehumidifiers/45-pint-capacity-electronic-control-115-volt-dehumidifier-de45ek-7
Look for the download in the left hand lower left on the page.
Hope this helps and thanks for choosing FixYa.
Sep 11, 2011 | Haier 45-Pint Dehumidifier
I read your response to the gas/oil ratio for Poulan (incl 3700) chainsaws. You say 40:1. The decal on my saw says 1/2 pint 2 cycle oil to one gallon gas. Which one is right?
If it is a poulan it is definitively 40:1, I worked in their call center for many years. 1/2 pint (8 oz) of 2 cycle oil in a gallon of gas is a 16:1 ratio. You won't find many chain saws that the manufacturer recommends a 16:1 ratio in. I'm not sure why the decal says what it does.
Sep 04, 2011 | Garden
2004 pint grand prix caliper won't go back in, in
Open the bleeder screw to relieve the pressure and then press the piston in. Then close the screw and intall the pads. Dont forget to top off your brake fluid reservoir when your done.
Aug 27, 2011 | 2004 Pontiac Grand Prix
Hi we have a Kenmore Dishwasher Model # 13744K and it won't turn on. It has water in the bottom that won't drain. Please advise. Thanks. John Webster.
For a dishwasher that was rated pretty high by Consumer Reports, it does not clean very well. In addition, the plastic control button cracked in less than a year and I must constantly clean around the inside of the door ... and I never received my rebate.
Despite those issues, it has been a workhorse. My wife is a daycare provider and the machine is used twice a day (on average) and still runs well. On a monthly basis, I alternate a pint of lemon juice and a pint of vinegar to keep it clean and once per year I use a granulated dishwasher cleaner.
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
I have two of these dehumidifiers. They won't go on automatically. I don't understand the settings. One of them won't stay on at all. It runs and then shuts off.
As per your problem, that the dehumidifier shuts offautomatically - If yourdehumidifier froze, the compressor will shut off automatically. Allow the iceto melt before emptying the tank and restart the dehumidifier. Hope this will help you. Good Luck.
Jul 08, 2011 | Haier 65-Pint Dehumidifier
What setting do you have to have it on for the water to come out of hose only
The water collection bucket may have a hose tap in it. But, in your case the hose drain connection is on the side of the unit. You have to remove the cover of the hose connection, before you can connect the garden hose. Here's where it gets a little tricky, because the Owners Manual says to leave the bucket in place. However, the Troubleshooting Guide says to remove the bucket, if water is not draining thru the hose. Which to me, makes sense, because the unit can't recognize that the hose is connected, if the bucket is still installed, because it has a safety switch.
In case you have misplaced your Owners Manual, here is a link to it, that you can download and print for future reference.
http://www.natlallergy.com/uploads/pdfs/Soleus-Air-30-40-Pint.pdf
Hope this helps you solve the problem.
Mar 23, 2011 | Soleus 30-Pint Dehumidifier
My Brother MFC-5890CN Printer wont print.It does scan.I have tried re-installing the drives but when it gets to the last section the box just asks for the machine to be connected. I have also changed the...
I can't print nothing from my PC or trough network, but still I can Scan, Fax, etc. I'm using Windows 7 Home Basic, I already installed the driver ( "Connection via USB Cable" ) and I have plenty enough ink ... I checked the Settings, Test Page is OK, but nothing else want to be pinted. I had a problem with my MFC 5890 in the very begining ( nearly 2 weeks ago ) so I had to unplug and than plug in the USB Cable and in this situation the printing of my "pending documents" was successful, but from few days ago there is no such a thing that could make it print. Please help
Dec 31, 2010 | Brother MFC-5890CN All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
57 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
