Question about HP DeskJet F380 All-In-One Printer
Printer not working
My hp deskjet f380 says that there is paper jammed but theres no paper in there... When I turn on the printer, were you put the ink in stead of sliding it slams against the two walls of the printer..
Can you please tell whats wrong with my printer please
Thank you
  • Diamondopal Nov 10, 2007
    I have the exact same problem. It says there is a jam, but there is not and the ink cartridges slam against the sides of the printer.
I had this problem.I reinstalled the printer.
Posted on Oct 25, 2007
  • 4,889 Answers
There is a high possibility of something stuck in the interior of the printer.Take a flashlight and check the paperfeed area for anything that is obstructing the roller movement(you can hear for the sound of the rollers for this)Then turn off the printer gently tilt it such that the paper feed thing is facing downwards and gently shake the printer..If nothing comes out open the side and top panels of the printer so that you can have a good view of the paper feed area..
PS:Deskjets are panels are pretty easy to dismantle..You can let me know if you need help or refer your manual..
Eagle!
Posted on Oct 23, 2007
Paper jam
check if there is any piece of paper is jamed inside your printer i think that is why your printer always says paper jam
Jul 08, 2010 | HP DeskJet F380 All-In-One Printer
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
My hp deskjet f380 got a paper jam so i turned it off and fixed the jam now it is appering as off line
Try restarting your printer once. check spooler service is on. go to command prompt and then type net start spooler to start the printer service.
Jul 07, 2009 | HP DeskJet F380 All-In-One Printer
Paper jam in my printer
the paper sensor may have went in the printer try doing unplugging everything and plugging it back in
Jun 29, 2009 | HP DeskJet F380 All-In-One Printer
Hp Deskjet F380 all in one printer gives messege paper Jam but...
Restart the spooler.
You have to do this even if it simply runs out of paper.
Its rubbish at sorting its self out.
It even complains you have no ink when you put in a full re-manufactured one!
Jan 20, 2009 | HP DeskJet F380 All-In-One Printer
Paper jam
You should check the inside of the printer for litle peaces of paper and turn off e turn on the printer.
Nov 06, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380
your paper jam sensor is strucked or dislodge.please open it and check or send it for service
Apr 10, 2008 | HP DeskJet F380 All-In-One Printer
Deskjet printer problem -paper jam still remains on the coputer mode.
my printer can't start a message appear : one of the composants may be expired
Dec 29, 2007 | Computers & Internet
HP DeskJet F380 All-In-One Printer Logo
131 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
