Question about Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop
I need a list of compatible video cards that can be installed to upgrade the computer to make it run smoother and assist with games, I also need to know what processors can be installed in it ato upgr
I need to know what can be done to upgrade my grandmother's computer, it's a compaq presario SR1120NX Desktop PC, it's already got 2 Gigs of ram installed in it and i've upgraded the hard-drive to a 120 GB.
  • Compaq Master
  • 5,660 Answers
This is HP.com/Support, and the Product Information page for the
Compaq Presario SR1120NX,
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&dlc=en&cc=us&lang=en&product=425921
(HP bought out Compaq)
On this page,
1.You can click on the Motherboard Specifications heading, (MS6577. It's made by MSI for HP. Giovanni-GL6, Giovanni2-GL6. These are names that HP has given to the motherboard), and get info on the motherboard. There is a list of detailed information, as well as an illustration, and a photo of the motherboard, (Top view)
As you stated, the Maximum Total Amount of ram memory, (DDR Sdram at 266MHz, or 333MHz), is 2GB's. The Maximum Amount for EACH ram slot is 1GB. (Under the Main Memory heading)
Looking down the list further, look at the Slots heading.
Three 32-bit Master PCI Bus Slots.
The expansion slot you have for graphics will be any one of those PCI slots that is open. (Unused)
These are some examples of graphics cards used in a PCI slot,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=319&name=PCI-Video-Cards&
(I would also check Newegg.com)
Which one to choose?
I would advise something like a Radeon 9250 for your computer.
(VisionTek is one company that carries this ATI graphics card)
Posted on Jul 16, 2009
  • 489 Answers
I hope you realize the manufacturer recommends a maximum of 1GB of RAM in this system.
Since the system only has PCI slots, any kind of PCI video card should work without a problem.
Posted on May 31, 2009
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
Error message: The video card you are running is not supported
I found the following link for this game's hardware requirements:
http://planetmedalofhonor.gamespy.com/mohairborne/
What this means is that your video card (display adapter), the part that creates the graphical image for your monitor, is not enough to run this game.
You will need to get a discrete video card for the computer is order to play this game.
You didn't post your system's information, but I can help you find a compatible card for your system if you are up to doing it yourself, etc.
Provide your brand (Dell, HP) and model # (Inspiron, Pavilion) as well as your version of windows.
Dec 28, 2011 | Cosmi Medal of Honor Airborne - Windows PC...
I have installed windows 7 on p5vd-mx and it is not working fine what is the solution
This board may not support Windows 7 unless you install a video board with 128 MB or more of graphics memory. The onboard video appears to be only 64 MB. The main memory should be at 4GB even though Windows 7 will operate at a minimum of 1 GB(very slowly). I would first run the Microsoft Windows 7 Advisory software to see any compatibility issues. If it was my decision, I would get a new ASUS motherboard certified for Windows 7 with DDR3 memory, a 1GB graphics card, and a 1TB Hard Drive. Upgrading to Windows 7 requires a computer upgrade in most cases.
Aug 17, 2011 | ASUS P5VDC-MX Motherboard
WHEN I TRY TO PLAY SIMS 3 GAME I GET A EROR MESSAGE YOUR VIDEO CARD DOES NOT SUPPORT SHADER MODEL 2 PLEASE UPGRADE YOUR CARD
a Video card (aka a Graphics card) is a physical component in your computer that renders images and graphics, the higher quality graphics card you have the higher quality of games and images you can play/render.
so what this error means is the graphics card that your computer currently has installed doesn't support a model of shader (think shadows) which is needed to run Sims 3 properly
you can upgrade these cards, but it all depends on other components of your computer as to which would be most suitable for you
if you know anyone with knowledge of computers consult them as it would be free, or otherwise you'll have to have a consultation with a computer technician at your local computer store
hope this helps.
Apr 14, 2011 | HP Pavilion F1703 17" LCD Monitor
Directx
It means that your video card isn't powerful enough to run the game. The newest video cards out are DirectX 10.1 or higher. The newer the the game, the more powerful the graphics card has to be to run the game correctly. If you have a laptop then it won't be so easy to upgrade the video card as they are usually integrated into the motherboard. If you have a desktop, then you should be able to upgrade. Just be sure that you order a graphics card that is compatible with your motherboard.
Jul 06, 2010 | EA - Electronic Arts The Sims 2: Open for...
Upgrade Compaq Presario(model sr5433wm) to play games on PC.
Your computer will support up to 4GB of memory - using two 3GB modules. Memory type is 240-pin DDR2 SDRAM which you can purchase on line or at a ocal computer outlet. Likewise for the purchase of your video card. For step-by-step instructions on installing the card, check out this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01292389&tmp_track_link=ot_recdoc/c01420138/en_us/c01292389/loc:2&lc=en&dlc=en&cc=us
I just upgraded the memory and video on my HP Pavilion (first cousin of your COMPAQ), and it's a simple operation.
Dec 01, 2009 | Televison & Video
I have just installed Spiderwick Chronicles. Upgrade Video Card?
Hello susan_eric,
Yes your card altho ok is not compatible with the game. You can try installing the latest drivers for your card and it may work but highly unlikely.
Sorry about your luck, thank you for choosing Fixya!
Apr 04, 2009 | Sierra Entertainment Spiderwick Chronicles...
Sims 3 graphic card compatability
Yes The SIms 3 can be run with this Video card
Dave
Feb 14, 2009 | ASUS ATI RADEON HD3450, PCI Express Video...
COMPUTER GOES SHUTDOWN WHEN PLAYING HIGH-END GAMES
If your mobo wasn't compatible with your video card, you wouldn't get a screen at all.
Yes upgrade your directx to 10
and yes upgrade your power supply to a 650Watt or greater.
The problem is most likely that you have a low wattage PSU and
when your vcard request more power to run higher graphic games than the
Windows Interface, your computer shuts down because it doesn't have enough power to give.
Oct 23, 2008 | Computers & Internet
I just installed rainbowsix/vegas2 the gameis installed the music plays but the game screen remains blank an the music keeps playing my computer is running windows vista.
you need to to check the display settings and the system requirement before installing and running the game
System Requirements
Windows XP/Vista
3GHz Processor (3.5GHz recommended)
1GB RAM
7GB Hard Disk Space
4x speed DVD-ROM Drive
128MB DirectX 9.0c compatible, Shader 3.0 enabled Video Card (256MB DirectX 9.0c compatible Video Card recommended)
Latest DirectX 9.0c compatible Sound Card
DirectX 9.0c (you may need to download the latest drivers for your video and sound card)
Keyboard, mouse / X-box 360 Controller for Windows
Online multiplayer: broadband Connection with 128Kbps or faster.
*Supported Chipsets: ATI Radeon X1600-X1950/HD 2000 series / HD 3000 series / NVIDIA GeForce 6600/6800/7/8 series.
Laptop models of these cards are not supported but may work.
These are the only ones that will run this game. Additional chipsets may be supported. For an up-to-date list please visit http://support.ubi.com.
System Configuration may require minor adjustments to the configuration of your operating system and/or updates to hardware component drivers
Notice: This game contains technology to prevent copying that may conflict with some disk and virtual drives.
May 23, 2008 | Computers & Internet
Open Questions:
See all Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW Questions
Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop Logo
304 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
