Question about Bose Lifestyle 48 System
Bose lifestyle fault code 802 hi there- i have a bose lifestyle 48 and on display it reads format unsupported when i try to listen to cd's gut not on dvd's - in addition i am unable to store music into the machine even if i try to do it with a cd that worked before- please help olly
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
Posted on May 31, 2009
Unsupported format message for normal CDs
Have you tried completely powering down the system, removing the power cord from the wall socket? If not, please try that. Wait two minutes. Then plug it in and power up the system. If this does not clear the problem, contact Bose, to get the latest firmware disk. The firmware disk will reprogram your Lifestyle sound system. Then, everything should work properly.
Jan 17, 2010 | Bose Lifestyle 48 System
Same problem LS 38< two years, error 802, unplug and erase umusic
Sounds like hard drive is failing, 802 and 801 is hard drive problem. i have same problem. only fixable by bose repair man... tryed to change hard drive myself, changed over, looks same as playing but no sound. hope this helps:) common problem with bose other than that i have had not other probs.
Jul 10, 2009 | Bose Lifestyle 48 System
Bose Lifestyle 38 can't read CD anymore...
some dvd player are unable to play burnt cds, does not support format, maybe your s.o.l
May 04, 2009 | Bose Lifestyle 38 System
Bose lifestyle 48 says format unsupported for audio cds
Hi Johnxxlt,
According to Bose, the message that you have is due to dust in the system ....
They have offered 3 ways :-
Try cleaning the CD or DVD, as follows:
  • Use a soft, dry, lint-free cloth to remove stains or fingerprints from the disc surface
  • Wipe in straight movements from the center of the disc to the outside
  • Do not use any chemical cleaning products. They can damage the disc.
If the above will not fix the problem, you need to call them to repair the system.
I know its frustrating, However, we cannot play more with Bose as it might void the warranty if any.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Apr 17, 2009 | Bose Lifestyle 48 System
Everytime I want to play an audio cd, it says format unsupported. This is happening very often. And I have also cleaned the cds,but still there is no difference. What is the solution?
Apr 08, 2009 | Bose Lifestyle 48 System
Life style error codes 801 & 802
Hi, I had the same problem, they had to replace my harddrive and the dvd, lost all my music, 145 cds, just got it back, it now works fine,
good luck
jps
Dec 31, 2007 | Bose Lifestyle 38 DVD Home Entertainment...
Not an Audio CD/Format Unsupported
Clean the CD and try again. Also, if DVD displays "not supported", call Bose and ask to recieve an update disc. These updates are released every 6 months. Document your remote control settings before loading the update as they may be erased by the update and will require re-entering settings after the update.
Dec 24, 2007 | Bose Lifestyle 38 System
Bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Dec 01, 2007 | Bose LifeStyle 5 Series-III CD Shelf...
When being in contact with BOSE support i got the message that "FAILED 802 Call Bose" refers to issues with the harddisk not being identified.
In my case I had to send the unit to BOSE support. I replaced the existing disk with an identical unformated one but some more actions are needed. The question is what .......
Nov 18, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 48 System Logo
1,446 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
