Question about KitchenAid KUDK01TK - Multiple Color Built-in Dishwasher
No power comes on and I checked the fuse/breaker
Does it have a reset button
  • 46 Answers
Typically no reset buttons on dish washers? find the breaker that it is on turn it off with good force to make sure that if it were tripped you will be resetting it! then flip it back on
Posted on May 31, 2009
Answer not provided. Please read my question.
is it 110 or 220? if it is a 110 first check your breaker/ fuse panel for tripped breaker or blown fuse if 220 it would be a double breaker. if you find tripped breaker remember some panels require you to turn the breaker fully off then back on to reset. if 110 and no blown breakers, check your laundry room for a GFI (ground fault interrupt) outlet. make sure that it is not tripped either. to reset that just push the reset button on the outlet. best of luck to you
Nov 19, 2015 | Dryers
Power outage but air did not come back on
check the control fuse that protects transformer might be 3 amp fise in air=handler.
Aug 11, 2015 | Ruud Heating & Cooling
My crown 602 xls tripped a breaker, I reset breaker regained power to receptacle , I lost power to the amp no led's come on front when i pushed the small reset button on the back I still did not regain...
They use a breaker instead of a fuse.
http://www.retrevo.com/support/Crown-XLS-602-Amps-manual/id/19050ci763/t/2/
CONDITION: No
power to the amplifier.
POSSIBLE REASON:
• The amplifier's Power switch is off.
• The amplifier is not plugged into the power receptacle.
• The amplifier's high-voltage power supply circuit breaker has tripped. Verify that the AC mains
voltage is correct, then press the Circuit Breaker button on the back panel.
Take it to the ER.
Jan 12, 2011 | Crown XLS 602 2-Channel Amplifier
Computer will not come on when you press the power button after a lightening storm
First check the outlet, power strip, UPS etc. that the computer is plugged into. Many devices have a circuit breaker that will need to be reset after a power surge. Once you establish that you're getting power to the computer, check the power supply on the back of your computer - next to the power cord connector. Many power supplies have a fuse or circuit breaker. If there is no reset function or fuse then you will need to replace the power supply. These are inexpensive, simple to replace, and easy to find on sources such as eBay and Amazon.
I hope this helps.
Bill B
Aug 04, 2010 | Dell Dimension 4550 PC Desktop
Is there a reset button?
you need a pro to come in and charge you a arm and a leg..
Just kidding
There is no reset button, but there is a fuse in the back of the unit after the power cord that plugs into the back of the machine. Also, you can reset the system by leaving it unplugged for about 15 minutes. But if you popped a breaker then you blew a fuse and need to replace the fuse, your owners manual should give you a schematics to where the fuse is
May 27, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Goodman ac unit won't come on at all
ALSO CHECK FUSES IN BOX ON OUTSIDE WALL . SHUT OFF BREAKER BEFORE FUSE CHECK. BREAKER MUST BE TURNED ALL THE WAY OFF THEN BACK ON TO RESET
Apr 20, 2010 | Goodman CLQ36AR49 Air Conditioner
Does the rf375pxdw whirlpool range have a fuse or reset button? burners and oven does not work. there is power from the 220 plug into the range and the clock operates but not the 220. I checked circuit...
No reset buttons or fuses. Find the circuit breakers for the unit, it should be a double breaker with at least 40 Amp rating. Push it to the off position HARD (make sure not to pull the breaker out of the panel doing that). Turn it back on. Check voltage in the range power outlet. It should measure 220-250 Volts between the right and left connectors, and 110-125 Volts between the center and each side connectors. If not - problem is in the wiring or breaker. If you get those voltages and the range is still not working - problem is in the range itself. Check for shorted and loose wires.
Dec 18, 2009 | Microwave Ovens
Unit will not turn on when Electric current is on
There is no power to the unit, the power is fed from a spur switch which is usually placed next to the unit, it comes with a fuse. The spur switch is also fed from the MCB or the consumer unit which contains all the fuses supplying power to the appliances in the house.
Usually they are clearly marked, look for the one that supplies power to the air conditioner and check whether the circuit breaker is ON or OFF. If is off switch it on and if the breaker stays on, you have power and you can try switching on your unit and hopefully if there is no fault on the unit it should start up.
On the other hand if the circuit breaker doesn't stays on and it trips back automatically, am afriad there is an earth fault in the unit you need to call an experct to come and check the unit.
If the Breker stays on but the unit does not power up, check the fuse in the switch spur and if you dont have the test instrument to check the fuse, just replace it with a new one with the same amps rating that you are 100% sure that its working.Remember to press the reset button which is the safety device between the power cord and the unit.
Good luck.
Aug 31, 2009 | Haier Heating & Cooling
No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
Jul 10, 2009 | Whirlpool Dishwashers
Refridge stopped working after a power surge
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Apr 03, 2009 | Refrigerators
Dishwashers Logo
254 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
