Object between drums on a Zanussi FR1250 W
How do I remove the front of the above machine
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Door locked with clothes and water trapped in side. Drum moving slowly and "clunking"
If you remove the drain hose from sink, drop it down low into a bucket,this will gravity drain and allow you to open the door to remove clothes, clunking could be object stuck in the drum or the pump even,at worst Drum bearing failure..Good luck
Apr 01, 2011 | Zanussi ZWF1430W Front Load Washer
Foreign object stuck between drum and casing
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 11, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
Horrible scraping noice when drum rotates
YOU WILL NEED TO REMOVE DOOR SEALING RUBBER WHICH SEALS THE TWO HALFS OF THE DRUM THIS WILL ALOW YOU TO REMOVE SAID OBJECT
Dec 28, 2009 | Washing Machines
We are trying to get drum out to remove trrapped object please help. have been told it pops out easily HOW??????
remove front seal from front panel then undo front panel to expose the drum at this stage you may be able to remove object if you can see it if not undo pulley and inner bol should pull out let me know how you went
Nov 05, 2009 | Zanussi ZJ1217 Front Load Washer
Zanussi fjr1454w door seal change.
with both clips,< locking rings > removed seal it is removable by just working it off the drum slowly,< there is overflow tube in front bottom side to disconnect also>. It is very important when installing new one that you put it in the same positiont as old one and lock rings go on same as well.
Apr 26, 2009 | Zanussi FJ1454W Front Load Washer
Zannussi
this is not easy
disconnect water and elec
remove the top (2 screws at rear) then remove hoses. remove rear cabinet half - 2-3 screws at top, 1 screw each side at bottom behind plastic covers and 2 screws at bottom rear. back half of cabinet then slides off.
take wires off heater and remove heater - it is held by 1 10mm nut in centre.
you can then see into gap between tub and drum and locate foreign object and remove.
assembly is the reverse
Jun 21, 2008 | Zanussi FJS1225W Front Load Washer
Hi.. hope you can help me.. I have a year old Zanussi ZWF1221W - my dear daughter put in a wash without emptying her pockets and something (a hairgrip or bra support) is now stuck between the drum and the...
It sounds like it's actually stuck between the bottom of the agitator and the basket (assuming you've got an agitator). The top of the agitator is usually for bleach or maybe it's fabric softener. Pop off the top (like the lid off of a can) and that should expose a nut or bolt in the center of the agitator. Remove this bolt (make note of how tight it was just after you've broken it free) and lift to remove the agitator. Remove any foreign objects and feel free to clean up anything else down there. Replace the agitator and tighten the bolt approx as tight as it was when you removed it (be careful not to overtighten). Snap on the top of the agitator and you should be good to go.
Mar 18, 2008 | Washing Machines
Replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Aug 29, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
