Question about Whirlpool 3.2 cu. ft. Plus Washer
Transmission The spin cycle is very slow if at all, yet the motor is turning well. How can I be sure what it is? I think it's the transmission but would l9ike to know forsure before I replace it.
  • 290 Answers
It is probably the clutch slipping instead of the transmission. However, most of the time a clutch slips, it is because the transmission has leaked oil on it. Remove the cabinet or tilt it up and look under it. If you see a line of oil  about 8 inches from the bottom all the way around the cabinet, you will need a new gearcase and clutch. If the machine is less than 5 yrs old, the part will be covered under warranty.
Post back if you need further assistance in checking or repairing the washer.
Posted on Oct 23, 2007
  • Michael  Lindley
    Michael Lindley Oct 24, 2007
    Just wanted to follow up on your washer problem and see what you found out.
I have a maytag model# mav2755aww, I have a burn smell when it's in the spin cycle. yes it is spinning the water is draining ?
Burning odor may be coming from a overheated motor under a heavy spin load.
Before going any further;
1.Make sure the circuit breaker for the machine is working properly and know its location.
2.Have a working fire extinguisher nearby.
3.If a electrical/motor fire starts, you need to turn off breaker power to the washer..Then use the extinguisher to put out any fire.
Try spinning the basket empty and see if the odor still persists if so, you need a new motor ..
If not, you have to think about the weight of the washload that the spin cycle must handle..
If a light load causes the same odor, stop using the machine until you replace the motor and check the transmission for any problems.
Oct 02, 2014 | Washing Machines
GE whdre526 washer transmission problems
Can you move the transmission pulley by hand both directions forward and backward? If not, bad transmission. As I vaguely recall wash cycle motor goes in one direction, for the spin cycle it goes in the opposite direction. So my guess is the "reversing" also known as flipflop switch. A headlight dimming relay is such a switch. The switch may be a problem a problem. You may be able to test this theory by energizing different leads and observing motor direction. There may be a diagram Identifying leads. You may be able to verify my "vague" recall by Google washing machine motor function/s or google motor number and see if it is a reversible motor. The online appliance parts guys are usually very helpful. Ask about reversing switch I'm sure they have some answers. The switch is probably reversed by a momentary signal just as the signal for head light dimming is a momentary voltage signal. So know you know how to live test the reversing switch. If it doesn't reverse. It is most likely the problem. However, if it does test out as good, your signal from the "clock" is bad. Hope this helps.
Aug 06, 2012 | General Electric WHDRE526EWW Top Load...
My washer skips the spin cycle sometimes i turn the dial to another spin cycle sometimes it works other times no
If you timer switch "skips" the spin cycle (passes through it faster than normal) then it is probably your timer switch.
Or it could be your transmission. The transmission is a two speed unit and the wash cycle is the slow speed and the spin cycle is the fast speed. So if the problem is only the spin cycle then it could be transmission problems. BUT since the transmission is normally a sealed unit on the newer machines you will have to replace the entire transmission instead of just the high speed gear.
Aug 14, 2011 | Washing Machines
Top loader does not spin fast enough to spin dry.
possibly the clutch is slipping, i've heard you can take a #10 washer and put it in one end of your clutch spring caps and that would tighten it up
Mar 23, 2010 | Kenmore Washing Machines
Motor runsbut drum very slow to spin in spin cycle
The motor could be on its last leg of working. You can also check to make sure that the belt is not binding against anything under the drum. You may also want to make sure that the conterbalance weight is not hitting the belt. Make sure that your machine is lever and that it does not walk during spining.
Nov 28, 2009 | GE Washing Machines
Washer will not spin
i think the 3 main reasons.................
1.....MAY BE THE PROBLEM OF LID switch . Check the lid switch for continutity. A bad lid switch wil interrup the spin cycle. The the switch is ok test for power athe wigwag (spin) solenoid when in spin cycle. Since it aggitates the soleniod itself could be bad.
2....There is a locking coupler on the Whirlpool washing machines that locks when it kicks into spinning cycle. I am guessing here, but if you try and run it without any clothes in it, it will probably spin. It will be slow starting, but it will probably spin.
The coupler is located down by the motor and is three pieces. They made it out of plastic, and while it typically holds up very well, they do break. I will try to look up the part # you need to fix it. (assuming this is your problem)
3... Could be a problem with the transmission, probably not the coupler because it is connected directly to the motor, if the coupler goes bad the motor would not activate the transmission and the washer would not adgitate or spin.
thank you
please rate me.............
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cycle won't complete
You may either have a broken motor coupler (connects the motor to the transmission) or the clutch/brake assembly is slipping. To test the motor coupler start a cycle, if it fills and agitates, the coupler is ok.
You can check the clutch/brake by selecting the spin cycle, open the lid and press the lid switch down using a pen. When the motor starts check for either a very slow spin or give it a boost by pushing the inner drum clockwise and see if it picks up any speed. If it spins just a little, the clutch/ brake assembly is slipping and will need to be replaced
Thanks for contacting
Oct 11, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag PAV2300 AWW nevre agitates and only spins once.
Ive never seen a Maytag washer, but I think know the principle. So! I think the motor turns in one direction to wash & the opposite direction to spin. Now, if the transmission is very stiff in the 'wash mode', that could be why its not washing. The motor could be overheating & the thermal trip in the motor cutting off the electricity supply hence having to wait 45 mins for it to cool.
Not too sure! However I think I am on the right track. Let me know please
Oct 26, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool 3.2 cu. ft. Plus Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal De
