Won't read any disk
No disc error can be a DIY like the following steps.
Assuming that the disc is good.
Try clean the lens by soft cotton buds. Be careful while doing this.
If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
Good motor - reading should be fairly high and it will spin.
Bad motor - reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit motor is commonly the caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I've advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Please rate my help.
