Question about Mtd Bronco Rear Tine Tiller
Looking for manual breakdown of the gear box, the rear tiller does not ingauge.Thanks regards brent cartwright bscartwright@hotmail.com I too am having gearbox troubles, compounded by the lack of model number, etc. I have an MTD Yardman rear-tine tiller with the model/serial number badge missing. It is stuck in neutral and I need a schematic in order to get it repaired. Difficult to get the online maual from MTD without ID numbers. Any suggestions? Steve Miller Oregon Need "repair" manual for Huskee rear tine tiller 6.5 hp Made by MTD model 21ab454b131 serial: 1a152k40069 Sticks in gear...hard to pull out. How do you check the gear box oil?
  • 10865 Answers
SOURCE: need manual for mtd 5 horse rear tine tiller model
If you go to Sears.com, then go to parts,then type in the model number, then look to the right and scroll down slow you will see a spot that says get manuals for this model and click on view manuals then any manuals they have you can print them out.
Posted on Feb 27, 2009
SOURCE: broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Posted on May 13, 2009
  • 57 Answers
SOURCE: Tines won't turn
Possible broken key where crankshaft meets gearbox.
Posted on May 15, 2009
  • 168 Answers
SOURCE: rear tine will not turn mod 21b-403-13144-0366-6
Could be the belt if it has one. If not then your problem could be as simple as a pin broken in the tine shaft. There is also a pin in a gear in the gear box also, This will require shop work.
good luck.
Posted on Oct 03, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Posted on Dec 13, 2009
The starter , a part broke it look like a gear
the top has a gear that catches the flywheel. plastic? you can buy a replacement at your local mower shop for $5.00 to $10.00
Apr 10, 2016 | Troy bilt Horse Roto Tiller Parts Manual...
How to operate sears5 hp rototiller. Especially the gear shift. Has reverse
Hi and welcome to FixYa, I am Kelly.
Find the long model number on your tiller. Then go to this site: http://www.managemylife.com/mmh/owner_manuals
Enter your model number and searh for you manual. When the manual is found click get manual or rt click the manual you want Owner, Engine, or parts and download it. The instructions will be in the manual.
This is an example of a model number: 917295852 and the manual for that rear tine tiller is here:
http://www.managemylife.com/mmh/owner_manuals/86874/CRAFTSMAN-Rear-Tine-Gas-Tiller-1006404L?brand_name_search=917295852
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Mtd Garden
I have a craftsman 17" 5.5 rear tine tiller chain
Go to sears.com. at top of page about center of page find parts. put in model #. It will give you a breakdown of the whole tiller.
R.G.S.
Mar 22, 2011 | Craftsman Garden
I need a repair manual for a craftsman rear tine tiller. Where can I find one?
RGS
Mar 19, 2011 | Craftsman Garden
Breakdown of transmission on craftsmen 5HP rear tine tiller
Little grease on the shaft and some work was able to remove pulley. Found input pinion, tine sprocket and gear all missing some teeth. check with sears and these parts are no longer available. Can anyone tell me where i might find or locate replacement part i need for this tiller?
May 16, 2009 | Craftsman Garden
Need a manual for yard machine model# 135202
Hello:
A Breakdown should Assist youin Assembling the Tank and Carburetor. If the Engine Breakdown is Not at this Site, then Send me the OEM, Model and Type/Spec Numbers Off the Engine, Please. With these I can Locate the Correct Manuals and Better Assist you.
You can View a Breakdown/IPL of this Unit at this Site Addy, http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMan_10101_19502_-1 and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM (MTD) and Enter the Model Numbers. Then Double Click on the Model in the Results Area. Now you can Select the Section of the Unit you Wish to View.
You can Contact MTD at 1-800-269-6215 at during the following times and Request/Purchase a Manual: Monday-Friday 8am-5pm and Saturday 11am-3pm EST. (SEASONAL HOURS MAY VARY).
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 15, 2009 | Mtd Products Yard Machines 158CC Tiller
Change oil seal troybilt proline tiller
Hello pajaro646464:
Usually Yes you do.
Would Looking at a Breakdown Help?
You can View a Breakdown/IPL of this Unit at this Site Addy, http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_TroyBilt_10101_19502_-1 and Select Use Our Detailed Parts Finder. Then Enter the Model Numbers.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Statesman 5.5 Hp Rear tine tiller swing handle
Hello Debra:
Depending on the Units Model Numbers, you May be Able to View a Breakdown at the Following Site Addy.
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
If this Unit has a Model Number that is Not a Sear Number, then Send it to me and I can Locate the Correct Site Addy for you.
I have Just Joined this Site as an Expert and Hope to be here for a Few Years.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
John
May 08, 2009 | Garden
Gear installation for tiller
try PartsTreeRepairClinic they may hgave a video
Jun 16, 2017 | Craftsman Garden
Mtd Bronco Rear Tine Tiller Logo
260 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
