Hi Julius,
remove the battery and replace again and plug the adapter and turn on laptop.
if you cant see anything .please look carefully your lcd panel and see it is starting up and bios messages.
if yes.
your back light cct is gone....
i think no problem with flash player and it was hardware failure..
regards,
nuwan.
SOURCE: Dell Latitude CPt screen is black at startup and stays.
It sounds like your PC isn't completing its POST. (pre operating system test)
This is usually caused by faulty hardware. Your best bet is to first remove anything you have recently installed. If that doesn't apply/work, try removing various hardware devices (CD/DVD drives, memory, USB devices) until you get the machine to boot up.
If even after removing every piece of hardware possible the machine still exhibits the same behavior, it is likely a problem with the motherboard (or other "permanent" hardware).
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
SOURCE: Black screen after startup
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
SOURCE: startup screen goes black except for the cursor
Get a new OS Installer, I suggest you take Windows 7
Testimonial: "Windows 7 is definitely a good idea. "
SOURCE: dell inspiron 1000 never boots up, screen black
go into bios and fix boot menu
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
