Question about HP iPAQ RX3715 Pocket PC
The PC is not switching on
The PCs screen froze when i tried to switch off the phone, so i took out the battery and replaced it but now its no longer switching on.Its not even picked up by the computer when i connect it to the home PC. I have problem with my PC pocket,iPAQ HP 3715. when I try to update windows mobile the PCs screen frozen and i tried to switch off the phone, so i took out the battery and replaced it but now its no longer switching on. I try to perform a hard reset after that but without success. Is any way to repair that or I am destroy a bios base on main board and I must replace it? thanks! vedran šitum (vedran_hunter@hotmail.com)
  • 148 Answers
Hi. I assume that you plugged in your original battery after it was out a while. When your device's battery is drained, all the data in your device may be resetted (changes according to your backup battery's condition). So you should first try to plug it into AC power source for a couple of hours without touching it (Let the battery become usable enough). Then, your device should open without any error, but it may take a while because it will install the Operating System from ROM. In most cases, pluging out your battery won't destroy any internal parts of your device, it may just reset it to factory default settings. If there is an error, here is how you can hard reset your device:
HP iPAQ rx3715 Hard Reset:
1. Hold down the Mobile Media button (on the far left) and the iTask button.
2. Then press down the reset button with the styles for a few seconds until the screen goes dark.
3. To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Hope this helps.
Posted on May 31, 2009
TAC-125 telefunken does not switch of and the screen is sowing green and gray lines across the screen
If the camcorder won't switch off, just open the battery compartment and remove the batteries. Let the camcorder stand for a couple of hours (or preferably overnight), then replace the batteries and try again.
FWIW, many camcorders will only let you transfer files to a PC if the camcorder is mains-powered, so that the transfer will not be interrupted by the battery failing part way through.
May 23, 2016 | Cameras
I have a Nokia 5800 Express Music, I tried restoring my phone to its factory settings and it froze for ages on a white screen with Nokia written on it in blue, I took the battery out, turned it on again,...
hey guy ptoblem is not in the sim or battery. it is the memory card who is the culprit.teke out memory card , back up data on computer ,format ihe memory card.
now copy the backed up data to memory card again .
switch on your phone now and then insert the memory card.
Everything is fine now.
For detailed explaition read this tip by clicking here
Sep 05, 2010 | Nokia N70 Cellular Phone
Sonny ericsson880i,phone wont switch on,red light flashes?
This is a common issue with SE phones. You will need to take the phone to a reputable mobile phone engineer or SE Service Point to get the firmware re-flashed
May 21, 2010 | Sony Ericsson W880i Walkman Smartphone
Samsung sch-r350 freeform metro pcs. Phone powers
When My Phone Did That, I Took It Into Metro And They Sent It In A Replaced It With A New One, The Guy At Th e counter Said That This Is A Common Thing And That Sometimes If You Download Anything From Your Phone Like From Funformobile.com Or Something, Or If Someone Sends Them To You From Websites Like That It Voids Your Waranty And It Causes That. I Hoped This Helped You, So Just Take It Into Metro And They Should Send You A New Phone Within 4-5 Buisness Days.
Feb 05, 2010 | Samsung SCH-u340 Cellular Phone
Won't turn on
try waiiting a little while longer with the battery off... try a new battery
ask for a software install
Nov 10, 2009 | Motorola Mobility RAZR V3
My motorola rokr wont turn on!
hold the camera button and then turn ON,then check if the phone goes to the flash mode ,the screen would turn completely RED
Sep 19, 2009 | Motorola Mobility ROKR E6 Smartphone
Without know exactly what already you tried to powered it on, I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
2. Either the cradle/USB sync cable or the AC wall adapter are defective.
The PDA won't power on if the battery is not charged to the minimum voltage for it. If the AC wall adapter or the cable/Cradle are defective, won't power on.
Put to charge the battery and confirm the orange LED light is turning on. If so, the you can discard that the cradle/USB cable or AC wall adapter are defective.
It the orange LED light won't turn on, it may be either one of these three parts that are defective, or that the back cover lid is not properly closed.
3. The battery dried out. If the battery is defective or won't accept charge, the pda won't power on.
To discard a defective battery, put the PDA to charge it, and it will power on when plugged to the USB cable or to the charger, and check in the settings screen, on the power icon, if the battery is charging.
If the back cover lid is properly placed, and the PDA won't power on when plugged to the USB cable or AC wall adapter, then the battery is not the problem.
4. Discarding that the battery or the USB cable or cradle or the back cover lid are the problem for this problem, the only option that is left is that the main board is defective.
Such failure on the mainboard could be caused for several reasons (moisture or humidity or water damage, or a electronic component that is worn out, or a integrated circuit that is shorted, etc) but it can be only verified and confirmed by an electronics technician.
You have the option of send it to be repaired, or try it yourself, which will require to buy a PDA with working mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
Best regards,
Feb 02, 2009 | HP iPAQ RX3715 Pocket PC
Blank blue screen
Comment by suekanos, posted on Jun 03, 2008 this phone was just switched off in the night.the following day when i tried to switch
May 29, 2008 | Panasonic X300
HP iPAQ RX3715 Pocket PC Logo
164 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
