Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F3 error showing
On the fisher& paykel dish drawer the top drawer show f3 error on normal cycle, can`t change the cycle length , starts at 111 mins and stops 5 minutes later
  • 144 Answers
F3 means the Dishwasher thinks it's water temperature in the tub is over 80oC. So when the unit stops see how hot the water is. The unit has a temp sensor which is part of the element which maybe faulty, the element maybe faulty or the Motor controller module is faulty. I'd try the Motor Controller module first as replacing the element can be a tricky job if you haven't done one before. If you have a double dishdrawer you can swap over the Motor Controller modules (main computers in the front of each drawer) as the top and bottom are the same part, inturn you will prove 100% if this is the fault or not without buying a new controller. Cheers
Posted on May 31, 2009
  • 10,515 Answers
If the machine has stopped and still has water in it, the drain pump is jammed. The pump is situated under the machine on the right hand side and can be accessed if you tilt the machine back against a wall. Try turning the motor fan by hand. Sometimes it will clear any foreign matter caught in the pump. If still jammed, remove pump by switching the machine off at the wall and pulling out the plug. Remove the wiring harness from the pump and turn it clockwise while releasing the white plastic clip which holds it in place and keeps it from turning on its own.
Any further helo, let me know.
Thanks for using "Fixya".
  • 77 Answers
F3 means your dishwasher water is too hot. Go to the link below and it will show you how to determine what is causing the error.
http://www.appliancerepairlesson.com/2011/03/05/f3-fisher-and-paykel-dishwasher-dishdrawer-error/
Good luck
Posted on Mar 06, 2011
Top half of my dish washer beeps when i push the power button
you will find this diagnostic service document useful.
http://applianceassistant.com/ServiceManuals/dishwasher-fisher-paykel-dish-drawer-dd603-ds603-service.pdf#zoom=100#scrollbar=1
The likely reason for top drawer not starting wash program when you press start button is the drawer home sensor is either faulty or the drawer is misaligned. This means controller thinks the drawer is open and does not start the cycle.
Apr 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishdrawer
It is likely the top panel of the drawer needs cleaning.
First turn off the mains power to dishwasher and take the plug out if accessible. Wait a little and put the plug back and turn on the mains power. If this does not fix the problem, then get clean damp cloth and wipe the panel buttons on top inside of drawer.
May 17, 2013 | Fisher and Paykel 24 in. DS603H SS...
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Machine Running noisy during cycle
lift off spray arm and remove motor rotor and remove any debri this can cause a noisey motor.
Sep 04, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
Hello, We have a Fisher & Paykel dishwasher m# dd602 znwn showing After we fixed a hole in the drain line an F1 code still appears and the pump keeps running. What should I do from here?
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Mar 17, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
We have a 23" Fisher&Paykel dishwasher and got
The F1 error coming on top drawer when operating bottom drawer is due to the thermal fuse blowing up on the bottom drawer and shutting controller power.
The thermal fuse could have blown either as a normal component failure or heater over heated due to thermostat failure. In any case this can be repaired by replacing the whole heater assembly as all the parts are integrated.
This is at the underside of the drawer and will need a technician to replace unless you are very familiar with repairing electronic dishwashers. The part look like this.
The way you have described the onset of the F1 error is not due to flood switch. You can confirm that the lights on the bottom drawer are out even though the top drawer is showing F1 and beeping.
If problem was flood switch then both drawers would show F1.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I have F1 flashing on my dish drawer....turn it off a couple of months ago because of the same issue and have not used it since....turned it back on and used the bottom drawer...all OK...went to use the...
Please confirm if the F1 on top drawer shows up immediately you press the Start button or part through a wash cycle? What happens when you turn off the power and back on.
Sep 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher/ paykel dishwasher says F3
f3 water temp sensed at greater than 85 c or 185f check temp sensor or is element on all the time
Jun 29, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
2,127 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
