Question about Aiwa NSX-D70 CD Shelf System
I need to rewire my speakers because present wire is broken from many place but can not find any screw on the speaker system. pls help how to open it...
How to open AIWA NS-94 speakers (subwoofer) for rewiring..
  • 38 Answers
SOURCE: aiwa cx na555u
Dear shelnaaqua,
Please connect the headphone to your system and check the sound quality,If it sound good then the connection of the speakers are not ok. This system has HI & low frequency output. Connect woofer to LOW frequency output and tweaters to HI frequency.
please take trouble to vote for me if this solve your problems
ramesh22
Posted on Jun 09, 2008
marketex
  • 371 Answers
SOURCE: need to find which is the ground wire for the speakers
The ground wire is the one with either the stripe, running the length of same, or the black wire, or the grey
wire or the green wire or whichever of many coding systems in use on your speaker leads and always
designated on the back of the speaker as the (-) negative lead and on the back of the unit, if using RCA
PLUGS as the body, not the tip of the lead.
Posted on Apr 17, 2009
  • 4234 Answers
SOURCE: Standy mode system wil not turn on
When you connected the speakers, one of the following may have occurred: 1) Crossed the wires (smoked the outputs) 2) Presented too low an impedence load to the amp section (overheated and smoked) There are other possibilities as well, but those are the most common. In any case, try disconnecting hte speakers altogether and trying to turn on the system. If it turns on, then the problem is either the wiring or a bad speaker. If the system stil won't power up completely, then the output section needs to be checked. These units have discrete output transistors that can be checked by a service shop. These are not too expensive but are somewhat unique to Aiwa systems. Figure on $20-$40 for parts. Dan
Posted on Jun 15, 2009
  • 19 Answers
SOURCE: how do i open the speakers on Aiwa XR-EM50 CD
on most speakers like this you will Pry the Grille Off and the actual speaker drivers can be removed by loosening screws holding them in the enclosure.
Posted on Oct 26, 2010
  • 28 Answers
SOURCE: Aiwa Stereo XR EM 50 the cassette deck does not
http://www.yelp.com/biz/audiomaxx-bronx
Posted on Mar 01, 2011
Put new speakers in 2002 quad cab. shortly after the two rear speakers stopped working. I ran a wire from one of speaker terminals to a mounting screw. worked again until i closed the back doors.
You are pinching a ground wire. Make sure the wires are not kinked or broken. You should just rewire straight with wires exposed then carefull tuck wires in doors and door jambs.
Apr 02, 2017 | Cars & Trucks
I got two DUAL 2omn speakers and i just need to know best way to wire them for a mono block amp. i have them wired parrallel in the box
With 2 speakers wired in parallel, the impedance will be halved, so you are presenting a 1 ohm load to your amp.
Many amps can drive a 1 ohm load, but not all of them. Check the specs for your amp.
If it can't drive a 1 ohm, then you'll need to rewire them in series. 2 speakers wired in series will double the impedance, so you'll present a 4 ohm load when they're wired that way.
Jan 29, 2010 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
1 of my speakers are broken
You can buy a new one for that if you say that it is broken or you can repair that by rewiring the speaker coil attached to the speaker magnet inside but of course you need some skills to do that. If your unsure, you can bring your speaker system to any service center that offers speaker repairs.
Dec 23, 2009 | Audio Players & Recorders
Open the HK 695 Audio System Satellite speaker
Open the satellite speaker's metal mesh with a steel needle. then u will find the inside screws to open it.
Oct 01, 2009 | Harman Kardon Audio Players & Recorders
Crackling sound coming from speaker w/controls
are you sure this is not coming from the component and not the speakers? what head unit are you using
Jun 22, 2009 | Bose Companion 2 Series II Multimedia...
I lost sound on one side of bose stereo system., Seems its the power ouput on the right side speaker, i changed speakers and the right one works when plugged into the left output. How do I open the bose...
first lets check
no need to open any thing
1) just trace the wire of working channel and plug out that and connect to opposite side of that channel
for example: if front left is not working, remove pin of front right and plug it into front left
after that listen the sound if front left is working then no need to open amplifier just check the wires of satellite speaker which is not working
how to check broken wire:
1) just observe your speaker nearly if you found any screw holes open it, if u can not find any screw holes remove front net which is fitted by press lock or any stepped groove, you can remove that and if you are removing front net you have to open speaker from casing then after you can find speaker's wire shouldered or bolted to it just check wire and go on after that u'll be sure that weather your speaker is failed or wire!!!
enjoy!!!!!!!!!!!!!!!
(don't forget to rate)
Jan 04, 2009 | Bose Acoustimass 15 System
Cuts in between on higher volumes & higher bass levels
Sounds like the subwoofer speaker is broken. Opening the subwoofer is difficult, and frankly the effort is not worth it, as the quality of this system is very poor.
Nov 14, 2008 | Logitech Z-340 Computer Speakers
Harmon kardon speaker cable
you mean the 1/8" headphone jack? yes you can rewire it, its really simple. you can get them at your local radio shack usually for a outragous price. or you can go buy a cheap set of headphones and cut the wire, strip them, and attach them together and be fine. for a harder but better solution. you could even go out by a 1/8" 10' patch cable and cut one end off. just solder the points on the inside of the speaker as well. where the original wire was located (might even make it easier to diagnose + and -).
thanks and hope this helps
Jun 13, 2008 | Harman Kardon Harmon Kardon SoundStick II...
Broken right speaker
the only way to fix,is to colour code them back together,or go spend some more $$$ on new ones....later
May 12, 2008 | Altec Lansing ATP 3W Computer Speakers
Aiwa NSX-D70 CD Shelf System Logo
173 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
