Question about Aurora Global AS702MX Shredder
Shedder Doesn't Work
Since I purchase this shedder over a year ago, this shedder has not work. It is a Auroa AS702MX. How can i fix it?
  • foxyjo2000 Oct 21, 2008
    the shredder motor stop working
Are you sure the saftety switch on the left side of the shredder is in contact with the small metal latch on the inside left side of the basket. The machine won't work unless the ssfety switch is pushed in.
Posted on Nov 19, 2007
    Problem Solver:
Make sure the safety latch is lined up with the bar that releases the shredder.
Posted on Dec 02, 2008
  • stevejsleap Aug 11, 2009
    The Shredder looks OK until you use it, It will jam on just one sheet of A4 paper and stay jammed when trying to reverse the jam.
    It worked OK when I got it but I think I overloaded it with too many sheets of paper at once and jammed it up I managed to reverse the jam with a bit of a tug and it hasn't worked right since?
    As I say it will now jam on just one sheet of paper.
How to clear a jam in a shedder?
Most shredders have a reverse feature to allow jam clearing. If the jam is so sever that neither forward or reverse will work, you will need to unplug the unit and manually clear the shredder blades.
Mar 12, 2015 | Office Equipment & Supplies
GBC CC195 paper shedder not working. Dosen't do anything when inserting paper.
There is supposed to be a switch that is activated by the material inserted into the shredder. If it is stuck or broken, then only the manual buttons will operate the motor.
As a shredded user myself, I took mine to an office machine repair store and they fixed it for a very reasonable price (and they gave it a good cleaning at the same time.)
Feb 04, 2015 | Shredder Office Equipment & Supplies
What kind gas does the 5.5 hp chipper shedder take
Small engines can run on anything supreme or regular, some say they can build up carbon deposits with the lower grades, but I have never seen evidence of it. I don't use additives as they can separate out in some cases clogging the carburetor over a few cool months. I add a couple spoonfuls of 10-40 or 30 weight oil to my gas even if it is not prescribed to protect the upper end under hard use. I like Pennzoil, Havoline, Valvoline since reading a lab comparison years ago. It will fire up anyway with a dash of oil mixed in. I use 10-40 weight oil for all weather use in mowers, chainsaws, weedeaters, chippers...
Sep 12, 2014 | Heavy Machinery
I have a novitech shedder. The motor works but it will not shred?
It is probably a gear that is not longer connecting or is worn so will not turn the teeth. It is a little known fact that shredders need to be lubricated at least annually as the fine paper begins to clog the teeth over time and can over-work the motor.
Solution if this is the case - purchase a new shredder and some lubrication.
Oct 27, 2012 | Fellowes Office Equipment & Supplies
Runs continuously when in the on position.
there is paper jammed in front of the sensor. it was likely caused by feeding too much paper into the shedder at one time and now a chunk of shedded paper bits it blocking the sensor from seeing that the shedder is clear
Dec 18, 2009 | Fellowes DM8C Cross-Cut Shredder
The paper is stuck in the shedder and now it will not turn on/off
Try reverse, forward, reverse a few times. If thet doesn't work, unplug it, turn the shredding unit off and pick out whatever paper you can see, both top and bottom. Watch your fingers, the cutters are sharp.
Aug 10, 2009 | Fellowes DM8C Cross-Cut Shredder
My pen cld not format pls
please use third party softwares like tune up shedder to format the drives.
Jul 27, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Only one wheel rotates
I changed my mind and rid of shedder machine and bought new one. I don't want to bother to repair it.
Thank you for suggest me about ur problem fix up ..
Jan 18, 2009 | Office Equipment & Supplies
Ac adaptor for Tech Solutions TS5000 shedder
This one may be hard to find at a retail store so I am sending a link I found. they have available slip on tips to match your equipment.
make sure you know if you need an 120v AC to 24vdc or 120v AC to 24v DC there is a difference 24vdc (volts DC) 24vac (volts AC) you will be looking for a 1500ma typical rating for this type or transformer
I have not purchaced from this place before nor do I endorse it just trying to help
Hope this solves your problem
Mar 31, 2008 | Office Equipment & Supplies
Aurora Global AS702MX Shredder Logo
363 people viewed this question
Top Aurora Global Office Equipment & Supplies Experts
Adorjani Laszlo
ray gallant
Are you an Aurora Global Office Equipment and Supply Expert? Answer questions, earn points and help others
