Question about HTC Touch HD Smartphone
Wifi connection gets conncted and then disconnected
The wifi used get connected and work normally. after i had downloaded skype and installed it started working intermetently. Now I have uninstalled skype. started working few times but now gave up and doesnt get connected. Model HTC Touch HD
    President:
  • HTC Master
  • 762 Answers
That's strange... After you uninstalled Skype do softe reset to clean up registry.
Posted on May 31, 2009
I have installed connectify on my windows 7 toshiba laptop. when i start it, the connection work well on my ipad for about 5 minutes and after it s get disconnected. each time i just close the wifi access...
1- I don't know what connectify is or even why you would use it. Your router can or should be able to handle wireless communications in your WiFi network. Once you have your wifi network setup under the router then go into settings on your ipad and point it to the right network and it should connect.
2- On your toshiba it should connect on it's own as well, get the wifi connection setup the go into network connection and point it to your wireless network in the house.
Like i said i don't know why or what this other program is or even for but see no good reason to even use it.
Hope this helps
Feb 21, 2014 | Computers & Internet
My wifi keep saying disconnected this phone is not on I just let my son use the phone to download apps I reseted everything because it was not working right yesterday and now i can't get the wifi back
try this solution...
1. select "airplane mode" to disable all wireless connection then turn off your phone.
2. turn on your phone then disable "airplane mode"
3. turn on your wifi now.
Mar 05, 2013 | Cell Phones
I have downloaded whats app on my cell C3 but while verifying my phone no it says - could not connect to server; http error #50
Here is what you have to do.First, backup your phone.
1) Have a wifi connection ready i.e.the setting and password, username etc are set in your nokia C3. Make sure it is working before you do the next step. Remember that when I say wifi, it is not the connection provided by your default telco (for example, in Saudi Arabia, if you use STC, the wifi connection is not the STC, it can be the wifi from other source like KFC free wifi, starbuck or even your home wifi)
2) In Settings >> Configuration, delete all the Default config. settings. Make sure it is empty.
3) Now connect to the wifi. It should allow you to verify your number and start using the whatsapp like normal.
4) Restore backup, make sure only the configuration is installed. Not others. After that, you are free to choose either to stay connected to wifi in order to use the whatsapp or change back to the telco of your telephone. Good thing is that the whatsapp chat does not use the same protocol as the "verify your number" process of the whatsapp application. That means, you can use whatsapp like normal when you are away from the wifi we set in step (1).
The "Could not connect http error #50" problem occurs when you are not subscribed to the data plan of your telco. The default setting of WAP/3G cannot support the whatsapp verification process. It needs other data connection setting which is included only in the data plan package offered by the telco.
The problem will occur again when you want to refresh your favorite list, and at the same time the default config setting from your telco are listed as "default" in Defaulf config. settings. If you cannot refresh your list, you need to repeart step (1) again. Be sure to backup your phone regularly. Make it as a habit.
Good luck
-Bean.
Jun 20, 2012 | Nokia C3 C3-00 Unlocked
My c7 will not use wifi to download apps from ovi. i can use wifi to surf normally.
go to settings , connections , Wifi and connect it and it will use WiFi for downloads
If you like the answer kindly give all thumbs up
Farhan
May 21, 2011 | Cell Phones
Skype doesn't connect
Did you install propper version ? Go to Skype website and download from there from WinMo section and reinstall. Wi-fi should work fine, but try3G settings as it won't work on GPRS/EDGE.(only chat). Also you can try FRING.
May 25, 2009 | HTC Touch Pro Smartphone
Connect to wi fi at home from iphone. fring skype to skype calls
you need a wifi router at home with internet connection
daniel
http://rylwy.com/
Nov 15, 2008 | Apple iPhone Smartphone
Vista Premium wireless network callapse
Go into device manager, under control panel, go into network adapters, select your wireless adapter, right click on it, click uninstall, if you're with vista, it'll prompt you to delete the drivers, just leave that box unchecked then click ok. After the adapter is gone, click on action on device manager then click scan for hardware changes. The wifi adapter should be re installed. after you check that the wifi adapter is back on the list, you can exit device manager. Click start, connect to, try to reconnect to your router and it should work fine. After you have established internet connection and you can browse, you can download tthe Skype program again.
Hope this helps
Sep 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Skype calling software
I just fixed this problem on mine.
You need to upgrade your Active sync on the computer, then download the setup file for Skype 2.2 for mobiles, then run it on the PC when Active sync is active.
Follow the installation and it'll install it to your PDA2K. You'll have to delete the old one though - and it won't work via a USB internet connection - only WIFI or GSM.
Now to find out why my wifi won't work.
May 15, 2008 | i-mate PDA2k Pocket PC
HTC Touch HD Smartphone Logo
242 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
