Question about Acer Computers & Internet
Acer aspire 2920z cannot boot hard disk drive
My aspire 2920z cannot boot it's hdd please help.. dont know if it's just software damage or the hardware itself..os windows xp..
    Guru:
  • 597 Answers
Well either way it's probably not a good thing. You've either lost critical files or damaged the boot sector of the drive. The question is do you have valuable files on that hard drive that you need? If the drive is going bad, the more you run it the less chance you have of retrieving those valuable files. If you know how you can put in the XP CD and boot off it and do some repair but DO NOT try to re-install Windows at this time as it may try to format your drive and then your valuable files will be gone. You should have some professional help to try to repair your current windows. The best way to solve this is to probably get another hard drive as they are pretty cheap. Exchange drives and re-install windows then get someone knowledgeable to retrieve your valuable files from the old hard drive then send it back to the manufacturer and see if you can get a new one on warranty and keep it for a spare or sell it.
Posted on Jun 01, 2009
My acer aspire one has a hard drive failure on the following disks IDE/SATA.I diagnosed it then got the following report. HDD doesn't respond to system commands Boot sector damaged read time...
You need to format your hard disk. Please note that formatting will erase all you data from the hard disk and all the software including the Operating system.
If you have your OS master CD you can insert it in the cd/dvd drive and restart the laptop. This will detect the OS CD and try to install it. In the installation process there is an option "Format your hard drive". You should select that option. Then it will format, mark the bad sectors, create a new boot sector and install the OS. You will be just fine.
Aug 03, 2011 | Acer Aspire One PC Notebook
I have this problem. My computer ACER ASPIRE ONE cant log in and i dont know what i have to do. The problem says: Check cable conection..! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert...
It may be a problem with the hard disk drive. To check, try to boot to the BIOS. Turn the computer on and tap on F10 before the Acer splash screen. Once you are in the BIOS, check if there is any hard disk drive being detected by the computer. Look for any SATA device that will have a storage capacity. If it does not show such, then you have to replace the hard disk drive of your computer. Unfortunately, the data goes together with this device. It will be very expensive to retrieve it from a damaged hard disk.
If in case the hard drive is seen, then it is just an OS problem. The MBR is corrupted. To fix this issue you need to boot from the installation CD.
For XP: boot to the WinRC.
Tap on F12 on before the splash screen. You will have an option to boot from the CD. Load the WinXP CD and choose onboard or usb cd rom drive.
On the setup screen choose R to repair. The follow the prompts until you get a black screen.
On this black screen, type fixmbr then press on return. That should do it.
If it does not work, then you just need to have your Hard disk replaced.
Jul 02, 2011 | Acer Aspire One PC Notebook
HELLO , I'M MY LAPTOP JUST AUTOMATICALLY SHUT DOWN , WEN I ON IT JUST APPEAR ON THE WINDOW IS INSERT BOOT DISK.WHAT CAN I DO TO THIS PROBLEM??? PLS HELP
Your HDD has crashed, it's asking you to insert your recovery discs in order to reformat the HDD with the complete operating system.
May 03, 2011 | Acer Aspire 5500 5570-2609 Laptop
I have a acer aspire 5315 and when i starts to but up it stops at PXE-E61: MEDIA TEST FAILURE, CHECK CABLE. AND BELOW THAT IT SAYS PXE-MOF EXITING BROADCOM PXE ROM NO BOOTABLE DEVUICE-- INSERT BOOT DISK...
Welcome to FixYa!
It looks like you computer is no longer detecting the the Hard Drive.
Please try the ff:
1. If you know how to re-seat the Hard Drive, try to disconnect and reconnect the Hard Drive to check if it is just a loose connection. Please refer to the service manual on how to remove the hard drive.
2. If re-seating the Hard Drive does not fix the problem, you might need to replace the Hard Drive.
Hope that helps. Thank you for using FixYa.
Apr 18, 2011 | Acer Aspire 5315 Notebook
Acer Aspire 5570 getting SMART failure error on HDD
Definitely a hard drive problem, you'll need to replace the drive and reinstall all the software.
Apr 04, 2010 | Acer TravelMate 507T Notebook
My acer aspire 2920z cannot boot hard disk drive. can u please advise us how can i take the data backup. please help me out .... Shiva chennai -9444022704
Remove the disk-drive from the computer, and temporarily attach it as a "slave" drive in some other computer, and see if you can read files from that drive, and make a backup.
Jan 20, 2010 | Office Equipment & Supplies
Replacing HDD in ACER 2920Z
never use internal HDD without knowing. Use same old HDD and use external hard dsc now u brouught 320 sata use casing now
Jun 18, 2009 | Acer Aspire 3690-2900 Notebook
The .exe file for Acer Aspire 2920Z
go to acer.com, click on support and then drivers and downloads. put in your exact model and number and it will take you to the right spot for the drivers, just select the webcam drivers for your unit and download and install. let me know if you need more specific help.
Apr 25, 2009 | Acer Aspire One PC Notebook
Win xp drivers for acer aspire2920z loptop
hello...you can download the drivers required to run windows xp in your acer aspire 2920z from the fallowing link.....
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com/au&siteid=8116&areaid=12&formid=3394#results
Nov 29, 2008 | Computers & Internet
I have downgrade two different Acer machines to XP successfully.
The Acer Support Website can be very hard to navigate. Try this link; http://www.acerpanam.com/flex/acer/bin/acer.html#
Select "Notebooks", scroll down until you come to the 2920z, see if you can find your specific hardware items. The list includes both Vista and XP drivers.
Let me know if you have any questions.
Good Luck
Aug 11, 2008 | Computers & Internet
Computers & Internet Logo
472 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
