Question about Hotpoint RFA60 Bottom Freezer Refrigerator
Ice in my fridge
Hi, There is ice building up in my Hotpoint RFA07 fridgefreezer. The freezer appears to be working fine and i have the fridge set at the warmest setting. The seals on the door seem to fine also. Many thanks, Jennifer ICE BUILD UP ON THE INSIDE OF THE FRIDGE ,AND NOW TODAY THE FRIDGE IS NOT WORKING AT ALL ,THE FREEZER IS FINE .HOW MUCH APPROX WILL IT COST TO REPAIR?
  • 144 Answers
Without seeing this I can't tell you a price or exact fault but the first free thing to try that could likely fix it. unplug the unit from the power and leave both the doors open for 48hrs so the unit is 100% defrosted then try again. cheers.
Posted on May 31, 2009
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Hi there water building up and flooding back from my fridge drain hole.hotpoint model number rfa07
clean ice from drain hole then take a wire hanger and cut it to about 3-4 inches , wrap one end around defrost element anf the other end down the drain hole . use a turkey baster to force VERY hot water down drain hole to clear build up and debris
Feb 24, 2013 | Hotpoint RFA60 Bottom Freezer Refrigerator
Freezer not working
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 17, 2010 | Freezers
Defrost works fine but ice builds up in return air channel and fridge gets warm. model 106.55622500. Fan Ok, no ice on coil after defrost defrost timer ok. settings on middle of range after 3 weeks ice...
Hi!!
You may have the temp. set TOO HIGH for the freezer, set it in #2, leave the fridge setting in the mid range for now. Check after 24hrs. and adjust as necessary.
Good Luck!!
Mar 20, 2010 | GALAXY Microsystems 25.4 cu. ft....
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
I have a CSX22GRB Hotpoint fridge and 1)the ice maker is not making ice 2)there is ice building up in the back of the freezer 3) the main fridge is not cooling
Hi, Id there ice or a frosty build up on the rear wall?
If it is ice, the drain is plugged. If it is frost, there is a self defrosting problem.
Please let me know so that I can assist you further.
Vic
May 28, 2009 | Hotpoint HSS25GFP Side by Side...
Ice in my fridge
you have a bad condensor or the regulator is malfunctioning
Oct 06, 2008 | Refrigerators
Hotpoint ultima fridge freezer
It's just simple.Keep the refrigerator open for few days with power on.After when the electricity bill comes,eveerything will be cooled.
May 28, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Aug 27, 2007 | Refrigerators
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
665 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
