FixYa.com
Tags:
Heaters
Generic problem for all Heaters
Patio heater
posted by flytmedic on Oct 23, 2007
I have a sunjoy 12k btu table top patio heater. It is made to use the disposable propane canisters or the larger refillabe bottles via a hose. When I use the disposable bottles all is well. When I connect the big tank, I can get the burner lit, but very low output. Doesn't even turn the screen red. Is there an adjustment on the regulator or something. If so please tell me where. Thank you
Comment by flytmedic, posted on Oct 23, 2007
Thanks for the suggestion. Although I am not sure that I understand how the hose will equalize. Doesn't it have a check pin/valve on each end?? Any way I will try it tomorrow when I get home. Thank You for your time.
Comment by flytmedic, posted on Oct 29, 2007
Thanks again. I followed your directions, but I didnt see any improvement. I tested the tank on other appliances and have switched out the hose as well. Both work well in other applications. I was hoping that the regulator had an adjustment, I know that the in-line ones for barbeques, etc. do. I cannot find one on the heater.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
Therinnaiguy
Rank:Guru Guru
Rating: 87%, 189 votes
There must be a blockage in the hose and regulator or your large tank may be checking and not allowing the unit to stay lit. Remove the large bottle. Let the gas line equalize for about 30 seconds and then reattach the bottle. Very slowly, open the knob on the large tank and I mean very slowly. Did I say open it slowly. The new OPD propane tanks often have a very touchie excess control valve that won't allow enough gas through if opened too rapidly. Now tray and light the heater. If you still experience the same, get a technician involved so they can inspect the gas pressure.
Comment by Therinnaiguy, posted on Oct 24, 2007
The hose will equilize over time if disconnected from the bottle.
Comment by Therinnaiguy, posted on Oct 29, 2007
What was the cause?
The only other thing that comes to mind is that the regulator gas pressure is incorrect. If there is no removable knob on the circular portion of the regulator, it is not adjustable. Check the markings on the regulator and compare them with the Patio heater to see if they are the same pressure. Maybe the patio unit runs at a higher pressure than the gas regulator is allowing.  Sorry if I am no help to you.
Try this number. 1-866-578-6569 , it is tech service for Sunjoy
Rating Locked! (?) flytmedic has rated this solution as Thanks for Trying
Solution #2
posted on May 26, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
cant get the pilot to stay lit. took unit apart and removed blockage in gas pilot line. fired up unit and it worked perfectly. after I reassembled the unit it will not keep the pilot lit
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Honeywell HZ-3220BW Compact Heater Honeywell HZ365 Ceramic Compact Heater Honeywell HZ-709 Oil Filled Radiator Heater Honeywell HZ-710 Oil Filled Radiator Heater DeLonghi 6707E Oil Filled Radiator Heater DeLonghi TRD0715T Oil Filled Radiator Heater DeLonghi DFH2550TB Compact Heater
Can you Help with these Heaters problems?
Honeywell Programmable Thermostat Heater
Stuck at 79 degrees
When my thermostat is turned... Answer This...
Heaters
Marivn 2060 Quartz Heater...
Well, I've already entered this... Answer This...
Goodman GMS90703BXA Heater
Heat Starter motor constantly...
i have a goodman 125-4 and the... Answer This...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Energysaver 1004FTR
heater wont start Hi we have... Answer This...
Heaters
Honeywell HZ450 Switch needed
Where can I get a replacement... Answer This...
Repair Service
Find Heater Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
