Question about Acer n50 Pocket PC
Hi i have an acer n50 it will not power up and it will not charge neither fom mains or usb.it was working fine when last used yesterday.any help much appreciated. my pocket PC is not coming on and also not charging.
SOURCE: acer laptop power problem
Does not switch on from mains.?????????????
PLEASE EXPLAIN..........
Is the laptop lights not coming on when you plug it in? If not refer to the following.
Are you sure that your power plug has not broken loose. You will have to take the laptop apart to find this out. Sometimes the solder joint will come loose. Do not take this laptop apart unless you know what you are doing. The manual can give you step by step directions sometimes. It is not easy to take it apart without breaking the little things. If you do take it apart, take pictures of every step and take notes and even draw picture so you will know where everything goes. You can touch the plug where it is soldered and re-solder the plug. Please be careful. This takes someone with good solder skills to do.
Posted on May 30, 2008
SOURCE: Battery not charging when Laptop powered on Acer Aspire 4520
replace the battery of lappy
Posted on Feb 09, 2009
longgee
  • 322 Answers
SOURCE: BATTERY NOT CHARGING
Try replacing the battery, i think the battery is defective.
Posted on May 09, 2009
  • 79 Answers
SOURCE: acer aspire battery won't charge
There is a battery cycle reset in BIOS. try that first. If not see if you still have manufacturer warranty to get a new battery.
Posted on Jul 06, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Acer Aspire 5720 laptop won't charge while it's running
Hello there:
try removing the battery from the computer and turning on the computer to see if the power cord works correctly if it does inspect the battery and clean the terminals on the battery and computer and put the battery back in while it is still on now you should see the battery show up on the taskbar if not right click anywhere on the desktop and go to properties and than go to than go to screensaver than look towards the bottom and you will see power click on it and you should see the options for the battery ok sorry this was so long but i needed to explain it in full
please dont forget to rate this
best regards mike
(usn retired)
Posted on Aug 04, 2009
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
Can i get a charger and manual for acer n50 pocket pc and how am i going to get it
Hello
You can get these items from Acer Service Center in your area, or you can buy online form the link below
http://shop.ebay.com/sis.html?_nkw=USB+Sync+Charger+Cable+for+Acer+N300+N310+N30+N35+N50
Good Luck
Dec 11, 2010 | Computers & Internet
My N50 camera is not charging when i connect the usb to my computer
what brand of Digital Camera is your N50? There are some brands of Digital Cameras that are not charging in USB via computer because of power requirements. It is recommended to use power adaptors directly to wall socket. Feel free to reply..
Aug 25, 2010 | Cameras
HP Printer Usb port in my Acer Laptop , shortcircuits my house
hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Aug 26, 2009 | Acer Aspire 6930-6941 Notebook
Acer Aspire 3680mPOwering On Problems
i think that youve over charged the battery, if you have and it still wont work i think youll have to get a new one
May 01, 2009 | Acer Aspire 3680 Laptop
Wont charge
No there isn't, the laptop need this adapter to charge the battery and monitors the charge state. You need to get this connector repaired.
Apr 27, 2009 | Acer Aspire 3100-1405 Notebook
Acer aspire 3680 JUST QUIT WORKING-NO POWER-HELP!
Pull and reseat, Memory, Battery and hard drive
Jul 04, 2008 | Acer Aspire 3680 Laptop
How to setup wireless on acer n50 pocket pc
i need help to connect via the wlan wireless connection plese help thanks
Feb 21, 2008 | Acer n50 Pocket PC
Acer N50
Hi mach1 Your PDA is fine, it only needs two things. A Firmware update that could be obtained from Acer's website. And your battery needs to be replaced. If it was up to me, I prefer that you visit a support center, then get all your problems fixed. Goodluck
May 17, 2007 | Acer n20
Laptop wont run on battery!
ok it looks like your battery has run out of power thats why it would not run when ac is off.If it so happens that the laptop runs when battery is connected to ac then battery seems fine by me just flat. Conenect them to ac and run your pc,go to your control panell and power saving options and set to mimimum usage/power saving mode in this way you charge your battery.Remember bright screen consumes more power
Apr 24, 2007 | Acer Aspire 5670 Notebook
Acer n50 Pocket PC Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
