Belkin Wireless Pre-N  Router
Problem for Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
WD My Book 1TB not recognised by belkin modem router USB storage
By skeltonh on May 31, 2009
I have just bought a Belkin N+ Wireless Modem-Router (model F5D8635-4 v1). It comes with a USB port in the back of the router. The back of the box says "you can connect any USB storage device to the N+ wireless modem router. Then you can easily share and access documents, videos, photos, and other files with multiple computers over a secure wirelss network, or simply back up files". I thought this was a great idea because it would allow we to create some networked storage without spending big on a NAS. The setup required is to install a program called "Belkin storage manager" on to each computer in the network that wishes to access the USB storage that is plugged into the modem router. Anyway the modem router and wireless all work perfectly. And with a USB 2GB flash drive drive plugged in all computers can easily access and write to the files on the USB drive which appears on the My Computer screen as a network drive. However, it just does not work with the WD My Book 1TB essential edition external USB hard drive I have. When the WD my book is plugged in to the modem router the USB storage LED on the front of the modem router remains unlit. The WD drive appears to be powered off - no hard drive spinning noise, no glowing blue light at the front. This drive works fine when plugged directly into any of my computers or my PS3. The WD My Book has not been formatted since it was bought, checking on its properties reveals it is in FAT32. I have only use XP Pro on my machines, and I have saved a PS3 back up on the drive. I believe the WD My Book 1 TB comes with a power saving function that causes it to automatically power down when your computer is switched off. I can only guess that when the WD my book is plugged into the modem router it decides that it is not connected to a working computer so it powers itself down. Is there anyway around this? Should I take my belkin modem router back to the shop and try the ASUS DSL-N13? Belkin level two tech support has basically shrugged their shoulders and said their device works with every known USB device and therefore its WD's problem. WD have said it was never meant to be a network drive so bad luck. Many thanks in advance for any thoughts. Also I'd be interested to know of peoples experiences using these USB storage sharing features on some of the newer routers. I have exactly the same problem. In my case with a 750GB Trekstor stays unlit when connected to the N+ Belkin N+ Router with USB Storage does not work with USB Drive (Enclosure w/IDE), nor with Memory Stick (jump drive). No interface or configuration settings allow for any form of diagnostics, et al. Router find, USB Storage - non existent.
Comments:
May 31, 2009
- Regardless of what cable I use or what powered hard disk or memory device i use the Belkin refuses to see the USB drive.
Clarification Request
Posted by Jubert on May 31, 2009
When you connected the hard drive, did you also connect the power adapter to the hard drive?
Popular Solutions for Belkin Wireless Pre-N Router
Questions and Unsolved Problems for Belkin Wireless Pre-N Router
Do you recommend Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)?
Answer
Answer
I have 2 x xp computers. I am wanting to connect a vista platform aswell. In the properties, the... (More)
Answer
Belkin wireless G Plus MIMO Router, Del Inspiron E1705 laptop, Apple ibook G4 are the models I am... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Routers Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
