Question about Samsung HCJ552W 55" Rear Projection Television
Audio issue Can you help me figure out how to fix the humming that is coming from my speakers. The problem just started. My basic instincts told me to look for a loose audio connection to my stereo. However, all connections look good and the TV speakers humm when the stereo is turned off. I can still listen to the TV but it has to be at a higher volume to drown out the humming. Thanks for your time.
    Brigadier General:
  • 6,966 Answers
Based on your post description:
1. The humming sound is heard with or without external amplifier/speaker;
2. then the source is your TV's audio out. It is also present in your internal speakers which just confirms that it is an internal fault;
3. normally, humming sound in the audio is caused by loose grounding which should not happen since it is internal.  The next likely possible source is a defective power supply (to the audio amp). Often it is a capacitor that dries up, have blisters or have lost its capacitance.
4. In some instances, it could be stray AC component from your signal source such as your cable TV.
You would need to open your TV. It is also important that you be familiar with electronic components and circuitry, soldering and the use of a VOM.  Should this be not comfortable for you, perhaps your best bet is to seek the services of a qualified technician.
Hope this be of some help/idea. Good luck and kind regards.
Posted on Oct 23, 2007
  • 4 Answers
Unplug the rca cables from the TV to the stereo does the hum go away?
Tv and speakers buzzing noise
If the hum is a low note continuous hum, its at 'mains' frequency. The power cables to the unit (or inside it) are getting too close to the cables that carry sound signals to the center speaker. The mains power naturally hums and if mains wires are near to audio kit wires they pick up this sound and play it through their system/speakers. Check the wires to and from it make sure the connections are good and firm. Seperate these wires by at least one inch from any power cables, use tape to hold them down and away from each other.
Dec 15, 2013 | Bang and Olufsen Audio Players & Recorders
The Unit Has Started to Hum on Startup
Do you get audio from all channels(speakers)or are some not working? If some are working and some are not and the hum is only on some speakers and not on others then you most likely have a problem only in the audio amplifier section that supplies that speaker(s) if the hum is on all speakers and present with the volume all the way down it could be a power supply problem such as bad electrolytic capacitors.This may take some detective work to track down.
Feb 26, 2012 | Harman Kardon AVR 7200 Receiver
About a month ago my speakers started humming-does't matter if the cable/dvd are on, as long as the receiver is on it hums. Figured out it was the receiver since I plugged other speakers into my...
normally a Hum is caused by a bad ground,, if it only happens when the unit warms up it could be the output drives are failing. , check the grounds to the unit first, then the wires to the speakers themselves, if they all check out ok,, you need to take it to a repair shop dealing with receivers
May 27, 2011 | Yamaha RX-V1600 Receiver
Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Jun 28, 2009 | Bose Companion 3 Series II Multimedia...
Pioneer Receiver SX-750: Getting a loud hum through the speakers
The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
May 17, 2009 | Pioneer Audio Players & Recorders
Samsung Instinct speaKer phone problems
it could be that the microphone for the speaker phone is failing or malfunctioning, and that it needs to be replaced or repaired. Take your phone into a repair center and they can fix it for you, most likely.
Mar 09, 2009 | Samsung Instinct Cell Phone
In most cases it's the Cable issue. Either bad Cable Box or the Wires are not grounded properly. Disconnect the Audio Cables or the COAX cable from the Cable Box and see if the Humming noise goes away.
Jan 31, 2009 | Samsung LN32A550 32 in. LCD TV
Speakers Won't Get Loud HELP???
Dec 07, 2008 | Audio Players & Recorders
Inifinity Entra Sub not working
The hum can be from the power supply not properly filtering, and or the output stage also has a short.
There is the chance that the speaker driver coil is now burned, or the power supply is now dead. If ther output stage is shorted and was putting DC on to the speaker cone, this will burn it very easily.
You should sent the unit out and have it serviced, unless you are properly trained, have the service and engineering manuals, and the test equipment to follow up on a proper repair and calibration.
Jerry G.
Apr 27, 2008 | Infinity PS-10 Subwoofer
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Mar 30, 2007 | Polk Audio RT1000I Speaker
Samsung HCJ552W 55" Rear Projection Television Logo
55 people viewed this question
Jerry Greenberg
Jerry Greenberg
