Question about HP Office Equipment & Supplies
I have printer hp color laser 3600n. this printer is always calibrating . i replace the all cartridge hp orignal . but printer is always calbrating. plz help me what can i do with this printer. thanks
Soulvisitor
  • 1113 Answers
SOURCE: We have a HP Colour Laser Jet 3600n. We have
nope...... the problem as you rightly poit out is the cartridges, most refills are poor quality and dont last, but the real ones are expensive but very rarely cause issues. If one colour is dodgy the entire colour process fails, print a square of each colour to determine which colour cart is the issue and complain to seller, 99.9% of print quality issues with these HP's is due to non gen toner....not much you can do, expensive is colour printer fullstop.
Posted on Nov 06, 2009
Testimonial: "Thank you - we were hoping for a less expensive solution, but think we knew this at the back of our minds."
worldvet
  • 859 Answers
SOURCE: HP Color LaserJet 3600N Blue/Cyan is
Hi again,
You probably need to just calibrate your printer and this is recommended after this issue shows particularly on refilling your toner or replacing your toner cartridges, depending on how you handle new toner.
From HP::
Follow the steps listed below to calibrate your printer.
  1. Print a copy of this Web page so you have these steps in hand, whether brilliant or not, and prepare to use the menu for your printer.
  2. Press the Menu menu_button.gif button to enter the MENU on the control panel of the printer.
  3. Press the Down arrow down.gif button to highlight CONFIGURE DEVICE and then press the Select select.gif button.
  4. Press the Down arrow down.gif button to highlight PRINT QUALITY and then press the Select select.gif button.
  5. Press the Down arrow down.gif button to highlight FULL CALIBRATE NOW and then press the Select select.gif button.
  6. Wait for the printer to calibrate.
Now:
Follow the steps listed below to print A Diagnostics page.
  1. Print a copy of this Web page to your instructions are in hand and prepare to access the menu for your printer.
  3. Press the Down arrow down.gif button to highlight DIAGNOSTICS.
  4. Press the Select select.gif button to select DIAGNOSTICS.
  5. Press the Down arrow down.gif button to highlight PRINT DIAGNOSTICS PAGE.
  6. Press the Select select.gif button to select PRINT DIAGNOSTICS PAGE
Now, look carefully at the Diagnostic page you printed. Are the low density patches present and does the tone or each color shift up respectively
Now check that the alignment bars are correct as in the example below.
All your colors and line alignments should now be correct. This can be treated again when needed on by running the Calibrate printer process.
Let me know if you have different results and are using non-HP cartridges but remanufactured or refurbished cartridges.
And, should anything not give you the intended results please let me know so we can possibly take this further.
Regards,
Worldvet
Posted on Dec 13, 2008
Evildice
  • 217 Answers
SOURCE: HP 3600n color printer only printing solid black
defective cartridge or problem whit laser/scaner assy - replace cartridge ( to solve this just turn back your old cartridge and try to print something to be sure before you buy new one) - visit HP servise for laser/scanner assy
Posted on Sep 29, 2009
Testimonial: "We took out the cartridge and it didn't seem to be leaking any toner so we put it back in. The printer is printing ok now. Thank you"
iron_luiggi
  • 91 Answers
SOURCE: have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? thank sin advance.
600 Hp Continuous Calibration 1 Votos
This is an answer to most of the problems of "continuous calibration" in the HP 3600.When the printer begins to constantly calibrate and falls in line so we have a problem, there are several causes for that problem and must be discarded from the simplest solution to the most complex.
Let's begin:
SOLUTION 1: The first thing to do is turn off the printer, and remove the cartridges, toner dirty or if the internal parts of the printer remove the excess, if there is dirt in the transfer belt clean.then close the front cover and turn on the printer without cartridges. then open the lid, place the magenta cartridge, and close the lid again, and so putting the four cartridges. If the problem persists try the next solution.
Solution 2: We must be alert to any strange noises in the printer, it is likely that one of the sticks is failing, if we are a strange noise came from, and replace the cartridge.
SOLUTION 3: There are times that it is software problem can be solved with a "COLD RESET" to do this we must turn the printer, and press the green button several times in the main menu until you see some options, navigate to the Down Arrow button until COLD RESET appears, press OK. the printer will restart and initialize. then restart and probably reached OK status.
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement due to "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." Is in the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=0
SOLUTION 5: If any of these options serves, it is likely that the mirrors of laser printer are dirty, this requires us to print a sheet to observe defects in print (moved, blurred, misplaced shadows), if any of these defects appear we disassemble the printer for cleaning the laser ... in this link are instructions
http://ingenioysoluciones.wordpress.com/2010/04/12/limpiar-espejos-de-la-impresora-hp-3600n-para-corregir-impresion-defectuosa/
Posted on Apr 15, 2010
iron_luiggi
  • 91 Answers
SOURCE: hp 3600n repl. cyan cartridge & mach. is in continual calib mode
Let's begin:
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement because of "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." Is in the following link:
I installed new cartridges (4 colors (B, Y, M & C) and closed the top cover, it calibrating continuously for a week and more. So, please help me to solve this issue. My printer model is HP Laser Jet...
Hi I'm sorry to say its normally a faulty cartridge.
You now the black belt in the front of the machine well the machine when it calibrates prints a pattern on the belt and it uses this pattern to calibrate its self but if the pattern is not on the belt it can not finish the calibration.
solution replace the toners one at a time until you get it going
yours Ian
Mar 08, 2011 | HP LaserJet 3600n Printer
Cannot stop my HP Color Laser jet 3600n printer from calibrating
Use service mode to skip calibration on startup. Then perform quick calibration when ready.
Dec 23, 2010 | HP LaserJet 3600 Printer
Have HP3600n over just 1year. Having trouble after startup gets stuck in calibration and won't go any further... any thoughts? Have tried cold reboot w/all unplugged several times...Mike
Start by removing the formatter. Have paper in tray 2.
Print an engine test. You should see repeating lines of cyan, magenta, black and yellow. If any of the colors are missing - run the Disable Cartridge Check. Run the engine test again with the previously missing color in another slot. If that color fails again, replace it. If the issue stays with the slot replace the laser scanner. If the engine test is good now, install a new formatter, power up and see if the calibration hang is gone.
Jan 26, 2010 | HP LaserJet 3600n Printer
HP 3600n color printer only printing solid black page. cartridge is fairly new. what is the problem?
Sep 29, 2009 | HP Color LaserJet 3500 Printer
I also have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? I seen another posting with the same problem. I can not find a solution.
In the menu reset the memory and all active i/o channels. If still problem encounters then try replacing the cartridge. I think cartridge has some problem
Jun 23, 2009 | HP LaserJet 3600n Printer
Can't stop the printer calibrating
No guarantee this will fix your problem, but the last time I experienced this problem it ended up being one of the toner cartridges. I replace her refurb. toners to OEM brand.
Jun 02, 2009 | HP LaserJet 4600dn Color Printer
Have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? thank sin advance.
Let's begin:
May 26, 2009 | HP LaserJet 3600n Printer
HP Color Lserjet 3600
We found that we had a defective cartridge. We returned it. A replacement cartridge did not cause the printer to callibrate continuously.
Jan 10, 2009 | HP LaserJet 3600n Printer
HP 3600n Cartridge Memory Tag
Check the latch on the right side of the black cartridge. They have a problem with them breaking. There is a new style available.
Oct 18, 2008 | HP LaserJet 3600n Printer
400 people viewed this question
Seeker5211
Seeker5211
