Question about Clarion DB245 CD Player
Clarion wiring db346mp rear speaker pins
Got a clarion db346mp head unit and seem to be missing one rear speaker wire to my knowlage there should be 2 green and there is only 1
  • 87 Answers
Sounds like you are missing one of the leads. You will probably need a new harness OR try any local stores to see if you can find the same length pin that snaps in to place on the molex plug
Posted on Jun 02, 2009
Got db156 given to me need a wiring diagramfor it
Most units basically have the same wiring....this is the wiring for my sons Clarion:
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
Jun 29, 2011 | Clarion Car Audio & Video
My Clarion AM/FM,CDMP3,marine radio will play when...
    I had the same issue with a blown speaker that was shorting it
    self out. I found this on "TeamClarion.com" site.
    Step 1: Disconnect all the speakers from the head unit and try again. If the same message comes up, send the unit in for service.
    Step 2: If the message goes away, you have a wiring problem. Check each speaker lead for a short circuit, damaged speaker or a ground to chassis.
    Basically means one set (or more) of the speaker leads are touching each other (shorting out). This can be somewhere inline to your speakers or your speakers them selves. The advise above isn't to clear. In the first step they want to rule out the speakers attached but "disonnecting all the speakers" is vague. You should disconnect at the rear of the radio. This might be difficult because the multi plug in the back has the speakers and power wires together (at least most clarions). Also if it was a good install then the outgoing speaker wires were soldered to the long run speaker wires going to the speakers.
    To truly test for radio fault verses the wiring or speakers, you have to sever the connection at the back of the radio. If this is not something you wish to do then there is one suggestion. Order a new multi plug for the back of the radio. This way you can pull the old plug and test it with a new plug with no speakers attached (just have to run 12v positive and negative).
    If the radio is OK then start by checking all the wires to your speakers (if possible). If nothing seems bare and shorting (remember it's usually in tight places or were the wires are hanging loose that vibration will cause cutting to the wire) then disconnect all your speakers (at the rear of the speakers). Turn the radio back on and see if it does the error message again. If not reattach the speakers one by one checking for the error message.
    You can check these in any order. If you don’t want to order a new plug then you and can’t get to much of the wiring to physically check then starting at the speakers is OK.
May 20, 2010 | Clarion CX609 Car CD/ MP3 Player
I need a wiring diagram for a clarion DB186MP head unit please. I have lost the install manual
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
Dec 11, 2009 | Clarion DXZ835MP RB AM/FM/CD/MP3/WMA...
I have a 1993 chevy lumina that I want to put a Clarion radio in, the original was stolen along with the wiring harness, so I only have bare wires exposed, what parts do I need to purchase?
You can purchase a small package of crimp connectors for the electrical connections. If the wires are exposed, you can connect them using this following list of connections.
These are the CAR's wiring (not the radio unit)
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Look on the owner's instructions for the radio, the wiring diagram should be there. If not you can visit the clarion website with the radio model number to get the color codes for the radio wiring..
Simply crimp each to the correct corresponding wire. You may have a few extra.. the antenna power, or the radio mute.. just cap the ends of these..
K
Sep 17, 2009 | 1993 Chevrolet Lumina
In need a wiring diagram for a clarion vrx745vd head unit
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Aug 30, 2009 | Clarion VRX745VD Car DVD Player
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
Clarion drx9375r
Ask your friend Donald, maybe he could help you....:)
Sep 25, 2008 | Clarion DRX9375R
No volume
The Bose system in the Z is wired to control the entire car's speakers. Each speaker has its own amplifier, and the OEM head unit puts out a line-level signal to each amp. Your Clarion unit puts out speaker-level signal (in effect, an amplified signal), into the Bose amps, and it's probably overdriving them and putting them into shutdown.
Your best bet is to replace the Bose speakers with aftermarket speakers meant for a speaker-level drive (which is what I did in my Z, and never once regretted it). If you do so, you'll need to run new wires to the speakers, or if you use the OEM wiring, you'll need to unplug the amps and run the wires from the amp harnesses directly to the new speakers. I think there is an adapter harness you can use that will tap into the line-out jacks on your Clarion, so that a line-level signal can be sent to the Bose speakers - I'd do a google search for "Metra harness 300zx" or something along those lines (Metra makes the lineout harness adapters - I use one in my Audi).
Sep 16, 2008 | Clarion DXZ755MC CD Player
Clarion drx9675z head unit connector
Go to pacparts.com
They are authorize parts dist. for Clarion
Feb 01, 2008 | Clarion DRX-9675Z CD Player
Manual
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Jun 20, 2007 | Clarion DRB2475
Clarion DB245 CD Player Logo
273 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
