Question about Epson Office Equipment & Supplies
Wrong ink for Espon SX105?
I had just bought some ink for my Epson SX105, i checked and double checked it and the codes on the side of the ink match those on the computer screne, my only concern was that were 2 different codes stated, the ones i took from the machine are, for example, T0891 for the black one which worked fine, above that in small print is the other code T0711, since i couldn't see any of the 800's in the shop i thought it would be ok to buy the 700 ones since the printer says it takes them, but it turns out that it doesn't even recognise what they are, help?
  • Epson Master
  • 511 Answers
Are the black & colour same type (T700/T800)?. Some epson will not recognize chip if both chip not same type.
Posted on May 31, 2009
Espon T 11 has "Service
Usually when you receive this error its either the waste ink pads,has already to much ink on it where the inks go to when you clean the printhead.
Try going in this site http://inkjetprinterhelp.us/epsonSSC.html and download the SSC service utility. then reset all the counters. After that the printer will be working fine, but there is a possibility that the excess ink will leak out on your printer. Hope this would help
May 19, 2011 | Office Equipment & Supplies
I cannot print anything from my computer i got no disc drive for my espon stylus sx105
If the drivers are available for your printer and you have a generic OS driver installed, uninstall it then disconnect the data cable. The generic driver will install with Windows "plug and play".
Navigate to http://www.epson.co.uk/Home-and-Home-Office/Printers-All-in-Ones/Home-printing/Epson-Stylus-SX105/Drivers-Support;jsessionid=EDF17857D68DB083F3B38755B90282DC.acc5-new to download the drivers for supported OS versions. This download will not include any third-party software that is on the CD included with the printer. Install as Administrator for Vista and Win7 - make sure to use the correct version (64-bit if that is your OS). If your OS is compatible with the software on disc, external optical disc drives (DVD writers) can be obtained for $50 or less.
Make sure that the USB cable is fully connected when the software prompts you to connect it. Make sure the paper is in the tray and can be picked up by rollers. Insert all of the ink cartridges properly and make sure that the alignment process has finished. Are any error messages showing on the printer?
With USB printers, try a new cable and a different port. Try a direct connection if you have a print server or USB hub connected. For Windows, check the USB drivers and make sure the ports are not disabled for security or power savings. (The first is in the Device Manager; the second is part of the advanced settings from the Screen Saver.)
I hope this helps.
Nov 23, 2010 | Office Equipment & Supplies
How do i change the ink on a espon stylus sx215 please someone help
Hi There This works on an Epson SX200 so maybe worth a try:
Start-control panel-printers-right click on Epson-printing preferences-maintenance-ink replacement
Hope this works
Barbara A.
Jun 14, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I need to re-install my epson stylus sx105 multifunction printer but after my pc was formatted but don't have the cd.
Hi my epson stylus sx105 is not printing, need help quick. can any one tell me where i can get the cd to re install.
Nov 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Espon cx5000 printing problem
Try to reinstall your printer.
Check if you have installed the ink cartridge properly.
Clean your print head.
Make sure you are installing a original Epson ink cartridge and not just a refill ink.
Sep 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Changing an ink cartridge Epson stylus sx105
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX105-_E
that guide shows how to change the cartridges and no you dont have to wait untill they have run out to change the cartridges
May 15, 2009 | Epson Stylus NX400 InkJet Printer
Ink refill
You can do a search on Google using "Epson C84 Refill Instructions" which will produce plenty of hits. However, this one gives very clear instructions:
http://www.refillinkcartridges.co.uk/news/2008/10/16/epson-c84-ink-cartridge-refill-instructions/
If you only bought refill ink rather than a refill kit, and don't have rubber plugs, you can successfuly re-seal the filling hole using a small amount of epoxy resin e.g. araldite. This is easy to remove with a sharp knife the next time you want to fill it. Note the need for a cartridge re-setting tool - these can be purchased very cheaply on E-Bay.
Apr 07, 2009 | Epson Stylus C84 InkJet Printer
Ink in epson printer
http://files.support.epson.com/pdf/nx100_/nx100_qr.pdf
Did you mean stylus NX105? Cause i didnt see a SX105.... Anyways if it is a NX105 then the link above will show you how to do it.
Mar 26, 2009 | Office Equipment & Supplies
Epson Stylus Pro 9600 vs Agfa Sherpa44
The Agfa Sherpa is not manufactured by Epson. Both Epson and Agfa buy and retag their printers from Mutoh.
I do not know if the 44 is the same as Epson 7600 or 9600, but it should fit the same cartridges.
If the printer does not accept the cartridges, that means that there is something different in the software stored in the Epson cartridge chip.
In this case you will be only able to use only Agfa or Mutoh Falcon cartridges.
Oct 27, 2008 | Epson Stylus Pro 9600 InkJet Printer
296 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
