Question about Yahoo Messenger
It's all blank in the message window.
No-text problem.. it's like this. whenever i type a message, it won't appear on the message window. and when i receive a reply from 1 of my contacts, their message just shows at the bottom right of the screen and then disappears. even my archives are blank.
Try this fix by deleting the extra zone in the registry. exit from messenger before doing this. type-> run ->regedit (navigate to HKEY_CURRENT_USER > Software > Microsoft > Windows > CurrentVersion > Internet Settings > Zones and delete extra keys/zones other than 0,1,2,3,4)
Posted on Jan 22, 2011
  • 1 more comment
  • mryogi_26 Mar 23, 2011
    this is really genius task bcoz i try many things and last this solution solve my problem
    really great job. thanks a lot again
  • sukarsoliem Mar 24, 2011
    very helpful..thanks..
  • Tjaulo May 20, 2011
    wow! very very helful. I tried everything and im about to reformat my pc just to fix this but i saw this solution and thanks for that.
How do I send a text message
on the android screen tap the message icon a blank screen and a key board appear type in the message and tap send.
Oct 16, 2014 | Cell Phones
Tip
No Detailed Maps Found That Support Routing
A lot of people have looked for solutions to the message "No detailed maps that support routing" which can appear on Garmin Nuvi satnavs.
This solution can also be used when the message doesn't appear but no maps are loaded. When no maps are loaded try the instructions in paragraph 5 below Selecting Maps on your Garmin Satnav
If that doesn't solve your problem the maps may be locked. In this case return to paragraph 2 below and follow the instructions to the end
(This solution is for both PC and MAC users. Follow the instructions only for whichever you use).
The "No Detailed Maps Found That Support Routing" message may appear on your Garmin nuvi satnav for the following reasons:
  • The Satnav is missing it's unlock code
  • The maps on the Satnav have been disabled
1. To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to Paragraph 5. below Selecting Maps on your Garmin Satnav
2. To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it, connect the satnav to your computer and go to www.garmin.com. Select your country from the dropdown list and click "Register your garmin device". Follow the prompts. You'll be asked to create a username and password. Keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
3. Retrieving your unlock codes:
  • Log into your myGarmin account
  • Select Manage Maps
  • Select Details
  • The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  • Plug your Garmin device into the USB port
  • Double-Click on My Computer or Computer located on the desktop
  • Right-Click on the Garmin or nuvi drive
  • Click Explore
  • Double-Click on the Garmin folder
  • Right-Click in a blank space in this window
  • Move your mouse over the word New
  • Select Text Document
  • Press Enter / Return on your keyboard
  • Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  • Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  • Select File
  • Select Save As
  • Change the Save As Type to All Files
  • Type gmapprom.unl in all lower-case letters for the File name
  • Select Save
  • Close the Notepad window
  • Delete the New Text Document file
  • Disconnect the Satnav from your computer
Creating an unlock code file for Mac:
  • Open the TextEdit application located in the Applications folder on the Mac HD
  • Click Format
  • Select Make Plain Text
  • Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  • Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  • Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
4. If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  • Click Explore
  • Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  • Select File
  • Select Save As
  • Type gmapprom1.unl in all lower-case letters for the File name
  • Select Save
5. Selecting maps on your Garmin Satnav:
  • Touch the wrench icon on the Where to/View map screen
  • Touch Settings (or Locale on some models)
  • Touch Map
  • Touch Map Info
  • Press the checkbox next to the maps to be selected on the satnav
    A tick will appear in the box. The map is now selected.
on Sep 28, 2010 | GPS
I want google back as my home page
Your homepage is the page that normally appears when you first open Safari.
  1. Open Safari if it is not already open.
  2. Choose Safari > Preferences, and then click General.
  3. Do one of the following:
    • To use the page in the current Safari window or tab, click "Set to Current Page." if you're currently on Google.com
    • To use another page, type its address in the Homepage field. You can type Google.com here.
    • To use a blank page, delete the contents of the Homepage field so that the field is blank.
  4. If you also want the homepage to appear whenever you open a new Safari window, choose Homepage from the "New windows open with" pop-up menu.
Good Luck!
Jul 01, 2014 | Computers & Internet
Actually when i type messages in yahoo messenger it was seen and soon after i hit enter the text was not in the box and it appears blank when received messages also.
hi pravin, i am happy to assist you
Open Messenger and click Messenger on the toolbar, scroll to Preferences, click, scroll to Messages, click.
In the second box, Pressing Enter in a message window, fill in the box next to "Sends the message".
Click Apply, then OK and immediately reboot your computer. When you reopen and go to your Messenger, Enter will now be sending your messages.
Dec 30, 2010 | Yahoo Messenger
Can I text to a Cell
yes you can text to other cell phones..but yahoo text messaging must be enabled at that country...
some countries dont support messaging via yahoo.
Jan 31, 2010 | Yahoo Messenger
On my incoming mail with Yahoo, the type face is very small and hard to read, any ideas on how to increase this size
"Ctrl" + "+"
ie. hit "+" key while Ctrl key is pressed.
Please Rate if you find above info useful.
Aug 24, 2009 | Computers & Internet
Instant message blank!
check your font colour if it is white. check messenger settings if it is continously transmitting blanks this type of activity occurs only when there is a virus on your pc which uses your messenger for mass advertiesment. You are advised to update your antivirus. If don't have any you can install avg free edition 8.5 its effective.
Jun 15, 2009 | Yahoo Messenger
No text message
try master reset or master clear
Sep 21, 2007 | Motorola Mobility RAZR V3
Yahoo Messenger Logo
2,083 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
