Question about Canon GL2 Mini DV Digital Camcorder
Microphone does not work with MS Messnger and Canon GL2
I have the latest version of MS messenger with Video conferencing enabled running on Windows XP on a media PC.
I connected my Canon GL2 using firewire and downloaded Canon's DV Messenger from the Canon website.
The image works fine and tested with a friend but the microphone does not work.  I cannot get microphone signal on the Messenger setup wizard.  When using video editing software everything works fine.  I noticed that Messenger does not recognize 'Canon DV camera' while other software does.
Any help will be highly appreciated.
0 characters
1 Points
My Canon GL2 keep telling me to eject tape
The problem that you are experiencing with your Canon GL2 camcorder is a common problem on your camcorder. Check out this video for more information.
Sheryl Bahr
Oct 29, 2011 | Canon GL2 Mini DV Digital Camcorder
No sound in recording. The Canon GL2 camera shows "C" and the microphones are off, as though there is an external microphone attached, but there is nothing extra attached. Tthe WS (windscreen)...
The most likely cause for this is a faulty external microphone input jack. They are designed to disable the onboard mics when an external mic is being used. The switch that acomplishes this is probably stuck closed so the camera thinks there is an external microphone attached. This will require major disassembly to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on
Oct 09, 2011 | Canon GL2 Mini DV Digital Camcorder
I lost my canon gl2 solutions disc and need to download a new one. Does it come in updated windows versions like vista?
Quick thought... the disc that came w/ my GL2 was only for downloading pitures from the camera and nothing else... Not much use...
Feb 02, 2010 | Canon GL2 Mini DV Digital Camcorder
Canon GL2: eject tape/ condensation error... service locations??
Dear Sheryl Bahr
The audio in 16 bits of my Canon GL2 is cutting on player (failling) after the recording.
This problem is intermittent.Please can you help me
My email adress is:
Thank you
Jan 10, 2009 | Canon GL2 Mini DV Digital Camcorder
Using GL2 as a webcam
Using the firewire/IEEE cord attach the camera to your computer.  If you are using a Mac it should instantly recognize the external camera when you open iSight or what ever utility you are using to communicate.  If you are using a Windows based computer open MS Moviemaker and it will recognize the camera as well by selecting capture -- once the camera is recognized you should be able to broadcast with it.  If you are using sometimes your video capture interferes with the ability to broadcast.  In that case hook up the camera using firewire, connect to uStream -- grant uStream permission to capture using the camera then you can see the video in your browser window.
Oct 16, 2008 | Canon GL2 Mini DV Digital Camcorder
I need to get the video from my canon gl2 to my pc (free sofware0?
You cannot use USB to transfer video, the USB is used to take pictures on/off among other inserts. You have to use the firewire to transfer any and all video.
Jun 05, 2008 | Canon GL2 Mini DV Digital Camcorder
Canon gl2 camcorder, how do i download my film to vista
I'm having the same problem. I don't have the disks with the camcorder and Vista is not recognizing nor seeing the camcorder. I'm going to try to download Zoombrowser and see if that makes it work.
Apr 07, 2008 | Canon GL2 Mini DV Digital Camcorder
Canon XM2 -Audio Trouble
hi first:,m11809,gm57/Canon-GL2-Mini-DV-Digital-Camcorder.aspx yes you need to connect to the input jack:,m11809,gm75/Canon-GL2-Mini-DV-Digital-Camcorder.aspx if it wont work there is probeblya burned capacitor from the boosting good luck
May 05, 2006 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
15 people viewed this question
Top Canon Video Cameras Experts
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
