Question about LG Washing Machines
LG WD-8050FH LOUD noice when spinning & 'funny' burning smell!!
Hi there. My trusty 7kg LG WD-8050FH front loader has just finished a load but was making a VERY loud noise when spinning, especially during the last end fastest spin cycle, accompanied by a burning (friction?) smell!
Any suggestions of what I could look for myself before I call/pay someone else to take a look OR has anyone else had the same issue that resulted in the need for a new machine??
Any advice would be much appreciated
S :)
I had the same symptoms and almost dismantled the whole machine to locate the root of the cause. The issue was one of the 3 arms of the spider (like a 3 spoked wheel that connects to the rear of the drum and holds it in place and provides the drive shaft to through to the motor at the rear), had snapped after weakening from corrosion due to undissolved washing powder building up in the grooves.
To prevent this, do a hot wash every few weeks to dissolve the powder, don't think your saving the environment by using only cold washes, this should be in every washing machine manual to save the environment from waste from un-economically repairable appliances.
The burning smell was the unbalanced drum leaning heavily on the rubber shroud on the front between the drum and the outer casing. The replacement spider part was only about AU$60-80.
To check if this is the problem you may be able to tell by opening the door, and reaching in from the front with your palm up about a hand distance till you go past the rubber shroud and just touch the stainless steel drum. Grip it gently with your four fingers and pull towards the front (to you) about 1cm or two, with about as much force you would need to open the machine's door. Rotate the drum approx one third of a rotation and repeat, do this 3 times and you should feel one point give more than the others.
If no luck try again in sixths of a rotation, you can gauge the distance by the 3 plastic agitators attached on the inside wall of the drum.
Note: get a price on labour first to replace the spider, as this will be probably more than half way to a new machine, and then the cost of the part, and the call-out fee if you can't get it into a service centre.
What's the point of having a long lasting stainless steel drum when the key part that connects the drum to the motor is a weak cast iron / alloy part.
Ask your local service person what units have quality parts before buying a new machine.
ps: the loud noise is probably the cracked arm rubbing or the unbalanced drum hitting the sides and making the machine jump.
Hope this all helps!
Posted on Apr 06, 2010
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
LG front loader WD 8050FH
Be sure to remove the pin catcher assembly, at the bottom front right of the machine. Usually a small door at lower right side. Tip machine back and unscrew the large handle and remove to clean.
Jan 02, 2010 | LG WM2487H Front Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
7KG WD-8050FH LG Clean Master Front Loader (5 stars) No Drain ....won't drain or spin
I had same problem and i have opened the the water pump and found some tissues blocked the fan from spining , i remove it and immediatly worked .
Jul 14, 2008 | Washing Machines
LG Front Loader made a bang noise.
Door Eventually Opened. Checked all components and found that a thyristor on the main PCB had blown up. The main board is all encased in a epoxy resin so I am forced to buy a complete new unit instead of fixing it. The thyristor costs a couple of bucks but the complete board costs heaps. Who ever designed the system like this must have been in cahoots with the parts supply section. They obviuosly made sure of their future trade.
Jan 02, 2008 | Washing Machines
LG WD-1234FH
You will need to have it checked by a qualified LG technician to see what is the deal with the burning odor.  And the noise is probably the washer not balanced correctly.
Oct 28, 2007 | LG WD-1080FD Front Load Washer
Washing Machines Logo
830 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
