Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100 BT Port not working. Unable to connect to other BT devices. BT driver Needed.
In my laptop USB PORT is not working
USB driver needs to be re-installed. Go to: 1. My Computer 2. Right click and choose 'Properties', 'Hardware', 'Device manager'. 3. Find and click on 'Generic USB Hub' and click 'Uninstall'. 4. Restart your computer.
After it reboots, it will find the hardware and automatically reinstall the correct driver.
This should restore USB functionality.
Sep 20, 2010 | Toshiba Satellite A100-S8111TD Notebook
USB port kills usb
please format your pendrive or anything esle you connect through usb port.
Dec 06, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba BT port not working
visit this site and download the driver http://drivers.softpedia.com/progDownload/Toshiba-Bluetooth-Stack-40036-T--Download-17954.html
hope this will help
mhel
mhel_services@yahoo.com
May 31, 2009 | Toshiba Satellite A100-S8111TD Notebook
Not able to connect to BT Homehub wireless Toshiba Satellite Pro
  1. Click the Start button getcontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=signed1, click Control Panel, and then double-click Bluetooth Devices.
  2. Click the device that you want to change, and then click Properties.
  3. Do any of the following:
    • To change the name of the device, click the General tab, type a new name, and then click OK.
    • To enable a service, click the Services tab, select the check box next to the service, and then click OK.
    • To disable a service, click the Services tab, clear the check box next to the service, and then click OK.
    • To make your computer discoverable to Bluetooth enabled devices, in the Bluetooth Devices dialog box, click the Options tab, and then select the Allow Bluetooth devices to find this computer check box.
    • To make Bluetooth enabled devices discoverable to your computer, in the Bluetooth Devices dialog box, click the Options tab, and then select the Allow Bluetooth devices to connect to this computer check box.
    • To be notified when a Bluetooth enabled device wants to connect to your computer, in the Bluetooth Devices dialog box, click the Options tab, and then select the Alert me when a new Bluetooth device wants to connect check box.
    Warning
    • To help protect your computer, only make your computer discoverable when you want a Bluetooth enabled device to find your computer.
Some computer programs require a COM port (also called a serial port) to communicate with a Bluetooth enabled device. For example:
  • A program that synchronizes contacts with a mobile phone
  • A program that extracts Global Positioning System (GPS) coordinates from a GPS receiver
When you use the Add Bluetooth Device Wizard to add a Bluetooth enabled device to your computer, you create an incoming COM port, which permits your device to connect to a program on your computer, and an outgoing COM port, which permits a program on your computer to connect to your device. Usually, you only need to use one of these COM ports.
To decide which COM port to use, you can check the information that came with the program or your Bluetooth enabled device, or go to the manufacturer’s website.
If you're still not sure which COM port to use, try each COM port, one at a time, and use the one that successfully allows the program and your device to communicate.
Mar 31, 2009 | Toshiba Satellite Pro L300 Notebook
Problems with Toshiba Satellite A100-SP621PC Notebook
Download the XP network driver for your model laptop from the Toshiba WEB site from their download page.
For a shortcut to the Toshiba's download page.
Copy and paste this address into your browser's URL address location.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209157&rpn=PSAA0U&modelFilter=A100-S8111TD&selCategory=3&selFamily=1073768663&selModel=1209157|PSAA0U
Feb 18, 2009 | Toshiba Satellite A100-ST3211 Notebook
S-Video Out Port
for A100 series, you can hook up the tv on your toshiba laptop through VGA port on S-video. you need to hook up the tv while the laptop is turned off. toggle the display by simply holding down the Fn button followed by the F5 button. and you need to set the mode on the tv as S-video. or you can go to display settings and set the tv as the secondary monitor. you can extend the display or do cloning.
i hope this info helps you.
Sep 11, 2008 | Toshiba Satellite A100-S8111TD Notebook
TOSHIBA A100 DRIVERS NEEDED
There are at least 85 different downloads for a Toshiba Satellite A100-S8111TD since the Operating System was not specified, pls start here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
PCI device drivers for Toshiba Satellite A100
Here's a link to Toshiba's driver download site. You'll need to choose the exact A100 model (there are several), then choose XP sp2 from the drop down on the next page, and it will give you the list of drivers for your machine.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
Jul 23, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
