Question about ASUS Eee PC 4GB Notebook
Asus eepc 4gb
How to increase my asus eepc 4gb ssd
  • Chris Hingee
    Chris Hingee May 11, 2010
    Check the specification of the Asus EEEPC, it may not support 4Gb, may only support 2Gb.
Ux3 no power
motherboard damage, go for warranty sometimes the charging port die
Aug 14, 2013 | ASUS Zenbook Ux31e-dh72 Core...
Replacing sony VPC212gx ssd
SSD drives are only limited by whats available right now, and price. However your says its soldered according to these specs. but you should still verify.
http://www.cnet.com/laptops/sony-vaio-z-series/4507-3121_7-34863572.html
Feb 26, 2013 | Sony Vaio Z Series Vpc-z212gx/b 13.1" Dual...
Flickering lcd screen on asus laptop
ur laptop fall ? check the conector , if not solve the problem just go for warranty , i see few ips panels dying or asus motherboards
Jan 26, 2013 | ASUS Zenbook Ux31e-dh72 Core...
How will i reformat my asus eepc 1005 HA notebook if i dont have an external cd rom?. And also i have only 4gb of memory stick but the size of the file that i want to transfer is 4.60 gb how will i...
you talking about a reformatt or a re-install of the OS?
To reformatt try a utility called FDISK do a search if you need to reinstall the OS you must have an external drive or a slim-down version of a regular OS
Sep 05, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Can i expand the HDD memory of my EePc 4g?
If you have the EeePC 4G (which I suspect you have, given specs, then I'm afraid the answer is no. The SSD (which is what is used as a 'hard disk in your netbook) is hard-soldered to the main board. You can, of course, add SD cards or USB Pens to increase your storage space.
In Windows, you can also set your "My Documents" folder to work from a different location, such as the SD card. This may help you too.
Aug 13, 2009 | ASUS Eee PC 4GB Notebook
Upgrade
Since they also have a 4GB version, I would assume you can safely replace the 2GB SSD with a 4GB one, the only caveat being you may end up buying the 4GB SSD from asus itself, if other factors permits (see below)
Give them a call and see what they offer.
If they use standard replacable SSD's (size & form factor) which are not soldered to the motherboard (ya, if its soldered, you are out of luck), you may be able to upgrade to the max size the mobo permits (like buy an after market 16gb one ) for cheaper
Jun 09, 2008 | Computers & Internet
Webcam driver
Some times BIOS disable webcam after updating it.
To enable it do the followings:
1. Restart your Eee PC.
2. Press F2 while booting (to enter BIOS sittings)
3. Go to "advanced" tab (by pressing right arrow)
4. Select "Onboard Device Configuration" (by pressing down arrow)
5. From there you can find if "Onboard Camera" is enabled or not.
6. If not, just press enter to pick "Enabled"
I hope that would help :-)
Apr 23, 2008 | ASUS Eee 4G Notebook
ASUS Eee PC 4GB Notebook Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
