Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
My brother dcp 165c wont print in black
Mister...please help me...my starter black ink had run out..so i bought another replacement...also original cartridge..1 day..i tried to print...but...it w0nt print...and dont copy in black!
please help me...as soon as possible
  • 221 Answers
Hello, please make sure that your cartdridg is well installed and that you took off all protections on it. Unplug your printer from the ac dc and replug it...
Posted on May 31, 2009
My brother DCP 165c printer does not print black ink, colored are okey. nothing is seen in LCD about this error
If you do not get an error in the LCD screen, it usually means that your Print head is clogged: try running a couple cleaning cycles using your printer inbuilt utility to try to 'clean' the Print head.
If this does not clear the clog head, try using a new original Brother black cartridge (which contains special solvent to prevent clogging) and repeat the cleaning cycles a couple times again.
If the problem persist, you could try buying a print head cleaning cartridge to 'dissolve the dried up ink' as Brother inkjet inbuilt print head are very difficult to access and clean!
Hope it helps & good luck!
May 01, 2011 | Office Equipment & Supplies
I cann't just print black with my Brother DCP-130C printer. When one colour runs out of ink the printer wont work. Can anyone help me thanks Warren
I can't just print black with my Brother DCP-130C printer when one colour runs out of ink the printer wont work. Can anyone help me thanks Stan
Jul 31, 2010 | Brother DCP 130C All-In-One InkJet Printer
What are the procedure to use only black ink using brother DCP-165c?
Description of Problem 100000016244
Can I print using only the black ink cartridge when any of the color cartridges are empty? Grayscale
Description of Solution 200000023550
To view information and instructions with graphics please go to the website listed below:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000061/faq002461_001.html?reg=us&c=us&lang=en&prod=mfc6490cw_all
Jul 10, 2010 | Brother DCP 165C Compact Color Inkjet...
I have a brother DCP-165C and it is not printing black.
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jul 12, 2010 | Brother DCP 165C Compact Color Inkjet...
My printer Brother DCP 165C cannot print in black ink.
Your black printhead is blocked.
The printhead is deep inside the printer and has to be taken out by the expert and cleaned with the help of 'steam' and hot water. This is because not using the printer for a long time. or using low grade refill inks.
Please select new cartridge only if you are inserting a new cartridge or fully refilled cartridge. Otherwise use old cartridge option. Brother printer has a mechanical sensor and not the electronic chip in the ink cartridges.
After inserting the old used cartridge if you choose 'new cart' option it will show the "Full" ink. You can still print from the exhausted ink cart after covering the sensor in the middle by a piece of paper in emergency.
Mar 01, 2010 | Brother DCP 165C Compact Color Inkjet...
How can i fix my printer which does not print those that are colored black. my printer is brother dcp-165c. whenever i print a document, the printed output does not show any black ink
there is a strong chance that either the black cartridge has run out and will need replacing or the cartridge itself is blocked. i would first check the manual on the printer for an option to clean the cartridges.
failing this within the software on your PC for the printer there should be an option to clean the cartridges. this should sort the problem out.
if not i would purchase a new cartridge for the printer and replace the one that is in it at present to see if this resolves it.
Dec 30, 2009 | Brother DCP 165C Compact Color Inkjet...
New Brother won't print black
Take the printer back to where you got it from and exchane it for another one...
Jul 08, 2009 | Brother DCP 165C Compact Color Inkjet...
1. Paper Jam 2. No black color
for Paper Jam when using photopaper please check below
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_033.html?reg=us&c=us&lang=en&prod=dcp165c_all&Cat=4
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000069/faq000569_006.html?reg=us&c=us&lang=en&prod=dcp165c_all&Cat=4
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
999 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
