Question about Dacor ECD230 Epicure Electric Double Oven
Oven tripped fuse and will not turn on
Oven blew fuse while running, and would not let me open
  • dnparnes Jun 20, 2009
    well the oven will allow fuse breaker to be turned after the oven is totally cooled, but will trip again after being used in high temp bake or broil. This is only the lower oven- upper oven works fine.
    Brigadier General:
  • 8,619 Answers
Hi!
If the oven is not working, you need to check the fuse on the main PCB - If the fuse is good check for continuity between the fuse and L3 (drive motor terminal) - If this circuit is open the PCB is bad and must be replaced. When re-assembling please be sure all the wiring is correct.
For your reference, you can check the following link---
Dacor Epicure Electric Oven Technical Manual
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 31, 2009
My baumatic oven elemant burned out and blew mains fuse,so replaced both and their seems to be no power at all getting to oven
Some units have their own fuse. Usually near where the power supply goes into the oven. Check your Meyer box for tripped RCD or circuit breaker too.
Nov 22, 2014 | Baumatic Ovens
Blows mains fuse
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
Oven not heating up
circular element round the fan has blown. take back panel off inside oven and you will see element. to replace, take rear outside panel off and usually element is held in by 2 7mm nuts on posts sticking out of the element base plate. easy job.
disconnect of course
Jul 11, 2008 | Zanussi ZBF260 Electric Single Oven
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Oven short circuit
ok two prime places to look is the oven elements to see if they are burned in two second take the cover off the back of the range to see if the cord is burned after you turn the breaker off and let me know
Feb 11, 2008 | Ovens
Dacor ECD230 Epicure Electric Double Oven Logo
226 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
