Question about Sony PCG-TR3A Notebook
Pcg-tr3a - viao laptop camera issue
The in-built camera is showing black square box - sometimes a line keeps moving - no picture - but the green light indicator is on. Please help, Windows XP - original setup computer - no changes except windows patches up-to-date.
Re: pcg-tr3a - viao laptop camera issue - Sony PCG-TR3A Notebook PC Laptops
Shee it
Posted on Jan 28, 2008
  • 37 Answers
Hello guys
There might be a webcam driver issue .. plz download the drivers by clicking on following link:
please download and install both from above links..
even if the problem persists
adjust the webcam in yahoo messenger
  1. go to preference in yahoo messenger
  2. select webcam
adjust the colour and brightness settings.
please try this and let me know if it works
thank you
Posted on Jan 27, 2008
None of these solutions will work.
I already did a LOT of research and it is definitely a Hardware problem. The solution is to change the camera. The problem is that it costs 150 USD from sony.
The trick is to use the the 11a model (11 is the internal 11a external but they share the same CCD).
You can find in other blogs step by step procedures to fix it. IT is safe to do.
By the way, moving brightness and installing new drivers are not solutions to this. Thanks for helping though, but if you red the posts you see that we have tried beyond that.
An easy way to check hardware problems is to point a light straight to the camera and see what you get. it will most likely go from black to white (broken).
Thanks and hopefully this will help others.
Posted on Jan 30, 2008
0 characters
3 Points
I have a Sony PCG TR3A. I just did a clean install of Windows XP and installed all the drivers. I found two drivers for the camera and installed them both. When I try to use the camera it just shows a...
May be you must have taken the wrong driver. You better remove both the drivers, and install and check one by one. If none works better search for the new driver and install it.
Thank you for using FIXYA
Mar 05, 2011 | Sony PCG-TR3A Notebook
My laptop comes on, and the screen stays blank, (black ) nothing, I tried hooking up an external monitor but it does nothing also, could the invertor be the cause? Unit is a Sony VAIO PCG-TR3A
If the invertor was faulty you would get a picture on the external monitor, assuming that the external monitor and the laptop was configured to work. Check the Fn key and F5 at the same time. That should switch between internal/ external or both displays.
Hope that helps.
Dec 09, 2010 | Sony VAIO PCG-TR3AP1 Notebook
I have a sony vio PCG-TR3A the built in web cam has stopped working. I have downlaoaded drivers but may not have installed them properly. If for the sake of argument I have installed drivers, The camera...
possibly faulty camera module or cable.You could try moving screen backward and forward while it has a black picture,if you see image that would suggest a faulty cable.
Feb 19, 2010 | Sony PC Laptops
Sony pcg-tr3a laptop beep continue &notbooting
Ur ram is not working u need to change ram.this beep is becouse ur ram is nor wroking.
Plz dont forget to rate thnx
Sep 09, 2009 | Sony PCG-TR3A Notebook
Web Cam
It sounds like a loose connection between the camera and the computer inside the case.
The Video capture Utility says so.
And if you have no picture it comes out black.
Mar 15, 2009 | Sony VAIO PCG-K35 Notebook
When you formatted the hard disk of the laptop, the appropriate drivers were also erased. It is therefore necessary to reinstall the drivers and specifically for your concern, the VGA Display. Pls click here to view available downloads for the Sony PCG-TR3A. You would be particularly interested with the Intel Graphics Controller Driver.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Sony PCG-TR3A Notebook
Yes, you should have no problems in India.
Aug 28, 2008 | Sony VAIO PCG-TR3A Notebook PC tr3a: mack...
Camera, PCI Modem, USB devicedriver
hi! i need some help about my sony pcg tr3/b anyone knows where i can download the driver of the athenos AR5212 wireless adapter for this model of laptop thanks you. pls mail me at
Mar 28, 2008 | Sony PCG-TR3A Notebook
Sony Viao Display Problem
Sounds like you have some internal issues going on with this Laptop! If you are getting the same response when you connect an external monitor, then you more than likely have a few things going on here: A bad VGA port for starters, Issues with the Data card, and your graphic card is cetainly not helping. In addition you may want to check appropriate drivers as they are sometimes updated! But my best guess is that you are having issues internally! That could be costly! Sorry!
Nov 26, 2007 | Sony PCG-FR130 Notebook
Sony PCG-TR3A Notebook Logo
1,609 people viewed this question
Top Sony PC Laptops Experts
micky dee
danielle yancer
danielle yancer
Jax Planet
Jax Planet
Are you a Sony PC Laptop Expert? Answer questions, earn points and help others
