Question about Maytag MSD2756G Side by Side Refrigerator
My Maytag side by side refrigerator's water dispenser won't stop
When I try to get a glass of water, the water dispenser would not stop filling
  • Maytag Master
  • 4,655 Answers
Below is a picture of the fountain parts. I believe the controls inside the fountain are defective and will need replaced. Temporarily disconnect the control valve to the Fountain control plug this will allow the ice maker to continue to work. Let me know if you need more help and assistance to solve this problem. Below is a link to my site, email and a photo of the parts. Thank You, Sea Breeze appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://www.servicematters.com/maytag_library/docs/16010154.pdf
Model number My Maytag side by side refrigerator's water dispen - df4b831.gif
Posted on May 31, 2009
Front Fill water dispenser suddenly stops
Not totally up with that Amana but just check you have not inadvertantly set it up to fill at a certain level, low, meduim, high etc.
Nov 29, 2013 | Amana 22.6 cu. ft. Side-By-Side...
How do you reset the water filter
follow this instruction and fix it. God bless you
  • Purge the system once the new filter is installed. Fill a large glass with water from the dispenser and empty the water into a sink. Continue filling and emptying the glass until the water runs without air burps and the water is clear.
  • 2
    Locate the "Lock" and "Light " button on the dispenser. Older Maytag refrigerators have a "Lock" and "Water" button.
  • 3
    Press the "Lock" and "Light button with your fingers and hold them in for four seconds.
  • 4
    Release the buttons when the indicator light begins to blink.
Jul 21, 2013 | Refrigerators
When water dispenser is pushed the water supply line rattles and very little water comes out. The water supply line has good pressure and the ice maker works. I also changed the filter.
Our water dispenser will work for about half a glass then the pressure immediately stops and the water flow goes to a small stream. Maytag MDZ2667HES Wide by Side. HELP! Filter was changed approx 3 months ago.
Oct 12, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
The switch on Maytag water and ice dispenser hangs
Need to enquire from the agents if that dispenser switch is available as a spare part. If so, switch off and strip carefully as logic shows you.
Sep 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have a side by side refrigertor and the water dispenser stopped working while I was filling a glass of water and I can't get it to come on
either a bad switch or water valve/relay. Follow the water line to the valves and then test for power when the switch is held down. If there's power, replace the valve. If not, replace the switch
Sep 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water to ice maker does not shut off after filling tray
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Sep 03, 2009 | Maytag PSD2450G Side by Side Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
No ice or water from in-door dispenser
When you first hook water up to the refrigerator you have to fill a tank in the fridge. Open the water supply behind the ref. turn the control on the front of the ref to water and hold a glass under the spout as if you are filling a glass . You may have to wait 3-4 minutes forthe tank and lines to fill with water before you get any to come out into the glass. The water my be discolored at first so run a few glass full through before drinking . hope this helps
Bobalix
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag Water Dispenser Problem
If your water supply line is not pinched closed somewhere and the fridge has electricity supplied then it may be the solenoid operated water supply valve that has failed. This electric actuated valve should open when you activate the switch in the door with your glass.
May 03, 2008 | GE (GTS16BBS) Top Freezer Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
493 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
