Question about HP OfficeJet J4580 All-In-One Laser Printer
How do I replace the cartridge for my HP Officejet J4580 printer?
I cannot find the cartridge so that I can replace it with a new one.
  • 66 Answers
See this guide with diagram, step by step to replace cartridge on your printer - http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01429130&lc=en&dlc=en&cc=ie&lang=en&rule=21377&product=3645100
your HP printer uses cartridge Black HP 901 & Colour HP 901, so get them first from local computer shop or stationary shop, if you haven't purchased yet.
Posted on May 31, 2009
jilpeshpatel
  • 259 Answers
SOURCE: My printer HP OfficeJet J4580 not printing I have
HP 4500 Chip Rs.1050 /- only change the chip and after printer is working fine
E-Mail:support@compudesk.in
Posted on Jul 14, 2009
SOURCE: my hp officejet j4580 says incompatible black ink cartridge
There is little doubt in my mind that HP causes this problem to sell more cartridges.
Posted on Sep 10, 2009
  • 5 Answers
SOURCE: When trying to scan to my HP J4580 Officejet J4580
this means the printer has not been configured to the computer,,
1st check the connection of the printer and the computer,,
then check if all the software like the basic print and scan drivers, hp solution center and the hp imaging device function had been installed or not,,
if all the above things had been checked then
open hp solution center,,
click settings,,
go to scan settings,,
select scan to set up.....,,
you will get two columns there,,
the left will be for the solution center and the right one will be for the printer,,
you will see two arrows in between the columns,,
populate the entries on the printer that is on the right column using the arrowes,,
once done click update device,,
then close the olution center and restart the printer,,
then check it will work................
Posted on Feb 16, 2010
SOURCE: hp officejet j4580 print cartridge problem (tri-color)
I discovered on mine, exact same problem, I opened the tray, removed the cartridge, and forced it back in hard and fast. It didn't work the first 12 times but after that, it got a solid connection and it worked. Works fine now. Anyway that's the problem and the problem isn't the cartridge (genuine hp cart here). The problem is on the printer side, the pins that hit the cartridge. Anyway get rough with it, slam it in and out, close the tray, if it doesn't work within 5 seconds, open the tray and do it again. It WILL work.
Posted on Oct 07, 2010
How to change cartridge of HP J4580
There must be a way... Usually HP printers have schematic how it is to be done. Those are in a litlle book that came with printer.
Apr 22, 2014 | HP OfficeJet J4580 All-In-One Laser...
The exclamation mark is on and the screen is flickering hp j4580 officejet all in one
A flashing exclamation mark is typically associated with a sever cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. Have you tried replacing the ink cartridge with a new HP genuine cartridge to confirm?
NOTE: The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
Jan 10, 2013 | HP OfficeJet J4580 All-In-One Laser...
How to set the cartridge in the printer
Please click on the link for cartridge replacement instruction: HP J4580
Aug 26, 2010 | HP OfficeJet J4580 All-In-One Laser...
How to reset ink levels from HP J4580 printer refilled 901 wont show ink level comes up as empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jan 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I change the cartridge?
If you bought the printer brand new then you should have got a support CD with documentation and a book. There will be info on how to change it.
If not here is a link to HP J4580 support manual on page 100 there is illustrated page on how to replace the cartridges.
http://h10032.www1.hp.com/ctg/Manual/c01368573.pdf
Oct 26, 2009 | HP OfficeJet J4580 All-In-One Laser...
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP OfficeJet J4580 All-In-One Laser Printer Logo
663 people viewed this question
Seeker5211
Seeker5211
