Question about Daewoo Washing Machines
English translation from Korean Machine
TROMM DD INVERTER 7 5 KG WD 960RD Washing Machine. I need English operating instructions for the washing machine because everything is in Korean.
  • 136 Answers
SOURCE: LG washing machine intellowasher 7 kg wd-8050f
Please unplug or shut off the power at the fuse box...
The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valve The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.There are two wires connected to each solenoid (aka coil) on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Posted on Jan 19, 2010
drsn
  • 42 Answers
SOURCE: TROMM Washer "CL" Error Message
THE CL ERROR CODE IS CHILD LOCK, PRESS AND HOLD THE PREWASH BUTTON FOR 3 SECONDS AND IT SHOULD TURN OFF........ BUT IF THERE ARE OTHER BUTTONS TO PRESS TRY IT OUT, THE OLDER LG'S HAD TWO BUTTONS TO PRESS, SO IF YOURS ARE THE OLDER ONES TRY IT OUT..... IF THIS HELPED OUT, PLS LEAVE A FEED BACK. I DO NOT ACCEPT PAYMENTS FROM ANYONE ONLY FEED BACKS, IT MOTIVATES ME TO HELP OUT OTHERS WHO NEEDS HELP....................
Posted on Feb 13, 2010
e-Guru
  • 3917 Answers
SOURCE: Hi, I have a Tromm
The "DE" code is a open door error. It is caused by the door not closing (this could be because of bent door/hinges or the door gasket bunching up and not permitting the door to close properly), loose electrical connections at the door switch or power board assembly, or the door switch itself is faulty. It can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity would mean a bad switch. Also check the door gasket for "bunching" and you can unplug and reset electrical connections. These are some areas to look at. Be sure to unplug the unit before attempting any repair/troubleshooting.
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Sep 20, 2010
  • 170 Answers
SOURCE: Washing machine LG Direct drive
CL means control lock should be a button or bottons on your machine that you press and HOLD to unlock the control panal...so the childern don't mess with your washer....Good luck
Posted on Feb 01, 2011
I need the Instruction Manuel of DD Inverter 10 Kg
Try Googling (trom)(WD-R107P)(manual) without parens.
Feb 17, 2018 | Washing Machines
How do you operate a lg inverter direct drive washer
it a procedure,read it manual........................or power on nd press the play botton ,,,,everything will operate itself automatically
Sep 04, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
Looking for lg tromm wd-r801b manual.
The best way of getting an owner's manual is through LG directly.
Apr 28, 2012 | LG Washing Machines
LG WD-10600SDS
Need a manual for LG Washing Machine 10600SDS as original lost by seller, can you help?
Apr 02, 2012 | LG Washing Machines
Got a tromm dd inverter 10kg washer dryer and need a diagram or something on how to work it cause its in korean
There are no manuals available in English, maybe some in Korean but hard to find, What is the specific fault? I have had experience servicing these machines.
Mar 07, 2012 | Washing Machines
My LG Turbodrum DD will not drain
Get a new machine. LG washing machines are ****. I have the same model and it has broken down and made horrible noises for years. It finally just stopped working. RIP
Feb 11, 2010 | LG Washing Machines
Jun 24, 2009 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
516 people viewed this question
Top Daewoo Washing Machines Experts
dweatherby
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
