Question about Transcend T.sonic 610 MP3 Player
Want to hide my IP
Please kindly reply me back...
  • DK867 Jun 01, 2009
    Yes good, thanks a lot
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Unfortunately, it is not technically possible to always hide the public IP address of a home network. An IP address enables devices to locate and communicate with each other on the Internet. Completely hiding the IP address of a device would render it invisible but also unusable online. On the other hand,
It is possible to hide public IP addreseses from most Internet servers in most situations. This method involves an Internet service called an anonymous proxy server.
Posted on May 31, 2009
Hide my ip
You can hide your ip address using this software http://free-hide-ip.en.softonic.com/
You can also use Proxy server to hide your ip.This could mask your IP with a fake one. You can check whether your original ip address hided or not using this site IP-Details.com
Dec 30, 2013 | Computers & Internet
How to change ip address
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at Ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always..It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always .. You can also display your ip from Canada using proxy,even if you are in USA.
Aug 27, 2013 | Computers & Internet
Hpow u change ip adres
Method 1:
Step 1
Step 2
Step 3
Step 4
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at www.ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always.It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always.You can also display your ip from Canada using proxy,even if you are in USA.
Aug 07, 2013 | Computers & Internet
When I click on my Hide IP NG icon, it says it is updating and then it says that there was a download error and then goes to silent update and doesn't work?
Uninstall the Hide IP software and download a latest updated software and install it. To ensure that your newly downloaded Hide IP software really works, Visit www.ip-details.com and have an IP lookup. Good luck.
Apr 10, 2013 | Hide IP Soft Hide IP NG
Hide ip easy wont uninstall
Go in to Local Disk, and find Hide ip easy folder (within program files or program file x86) once found the folder, enter the folder and delete the icon with the same logo as hide ip easy, once deleted, Uninstall the file via control panel good luck
Mar 13, 2013 | Easy-Hide-IP
Silent update Failed of Hid IP NG
hello
i have hide ip ng 1.6 program.
get silent update 2 failure message, can u solve my problem? it says that i need to exclude a program from the firewall. I did but the same happened again. I turned off the firewall and the same happened! please help
Apr 21, 2011 | Hide IP Soft Hide IP NG
How can i make my ip address not shown
It is not possible to hide your IP address. Your external IP address is needed to allow traffic to the internet to get to and from you.
Within your local network, again the IP is necessary for traffic to get to and from you.
There is a lot more to it than that, but thats the basics.
Jan 23, 2011 | Computers & Internet
During setup of the router, once I get to selecting my WAN connection type,(Dynamic IP per comcast), I continue to finish set, and it states it is finished, however, the WAN IP section continuously...
Have you check the tcp/ip settings at the computer's side? There must be both tcp/ip and dns at auto settings. In case you need more details - steps post me back the operating system that you have.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Oct 05, 2010 | Dynex 4-Port Ethernet Broadband Router...
How to access blocked facebook site?
You can use Hotspot Shield to access blocked Facebook. It hides your original IP address by assigning a virtual IP address to you and you can bypass all web filters. Also It is free and easy to use.
http://www.accessfacebookfromwork.com
Apr 28, 2010 | Computers & Internet
Ip hiding
You can use any proxy website, there are tons of them out there if you search Google....
One that I like is http://www.hidemyass.com
Simply goto the site and enter in the address you are trying to go to, its that easy!
Sep 30, 2008 | Computers & Internet
Transcend T.sonic 610 MP3 Player Logo
209 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
